Frontera Technical Support • View topic - leaking diff
leaking diff
leaking diff by lordrama on Thu May 08, 2008 10:53 pm
H can anyone tell me how easy it is to change a seal on a 2.2 petrol rear diff as mine is leaking and what tools i require
lordrama
Re: leaking diff by Red Oktober on Thu May 08, 2008 11:13 pm
I'm assumeing that this is for a 2.2 petrol A series frontera ....also assuming that you have a new diff plate
you need a 12mm spanner/socket ...drain out old diff oil first ...
undo the several 12mm bolts around the edge of the plate .....clean off the mounting surface on the diff
apply red sealant to the surface (no gasket) wait for a few mins ...then put the new diff cover on and bolt it down ..
refill with new EP90 oil
Re: leaking diff by Sir-Doris on Thu May 08, 2008 11:17 pm
If its just the diff cover plate then its an easy fix. Drain the diff, undow a few bolts, clean all the mating surfaces thoroughly, use some RED gasket sealant and tighten all the bolts up good. If the diff cover itself is leaking (as opposed to the gasket) then a new diff cover is about £55 (possibly + VAT) from VX.
If however the axle is leaking at the ends then new bearings/seals are required. These are, I think press fitted in and a pig to get out. There is a post about it somewhere, probably in the Axle section. Someone else will be along with a better idea then me though.
Re: leaking diff by Drift on Fri May 09, 2008 8:14 am
Re: leaking diff by Red Oktober on Fri May 09, 2008 8:52 am
Re: leaking diff by Sir-Doris on Fri May 09, 2008 10:13 am
So was it red or blue gasket?
Re: leaking diff by Red Oktober on Fri May 09, 2008 11:41 am
Re: leaking diff by Drift on Fri May 09, 2008 5:34 pm
I had to replace the blue sealant on one of mine two weeks later as it leaked, so used the red stuff, sealed it a treat.
Re: leaking diff by Wilberforce on Sun May 11, 2008 9:39 am
Scuse me if I'm being dense here, but why use red sealant instead of a proper gasket??
I ask, cos my diff plate's on the "things to do" list, hehe
Re: leaking diff by Drift on Sun May 11, 2008 7:36 pm
It recommended buy VX , also I dont think there is a gasket for that seal :wink:
Re: leaking diff by nitromotor on Sun May 11, 2008 10:10 pm
I use RTV Silicone sealer
Re: leaking diff by Sir-Doris on Mon May 12, 2008 12:26 am
Red sealant. Edited.
Re: leaking diff by Road Hog on Mon May 12, 2008 8:39 am
Black silicone gutter sealant.....Works a treat & the colour match`s.. :dance:
Re: leaking diff by Red Oktober on Mon May 12, 2008 8:54 am
could always do this ......
Re: leaking diff by Wilberforce on Mon May 12, 2008 1:48 pm
Very tempting actually, Carl...
If'n I can suss out a way to remove front and rear axles off my spare motor, then get what's left onto a trailer, I'll recon the diff on the back axle, paint everything up, and then fit it when the back end lift goes in :D
Just gotta work out how now, lol :lol: :lol:
Re: leaking diff by lordrama on Thu May 15, 2008 3:18 pm
Thanks you have all been a great help, just need to disable the alarm now as it goes off every 2 seconds/fix the heater if i can find the right relay hopefully and the jeeps in good nick
lordrama
