Frontera Technical Support • View topic - A seris lift
A seris lift
A seris lift by shaz-n-dave on Sat Mar 08, 2008 5:33 pm
I have been looking arronund about lifting my 1993 lwb 2.4 boddy / rear suspension wich is best it seems that when i hook my c/van it looks like the nose weight is very hevey when the c/van is empty i would guess that my leafs have gone but not sure shiuld i lift the arse end by 1.5 " or boddy lift remove spair wheel carrer wich will help best many thaaks dave :?
shaz-n-dave
Modifications: tilt colom s/wheel de badge bonnet crome nudge bar crome rear ligt
surround led tail lights led side lights led int lights new splash of paint
Re: A seris lift by alex on Sat Mar 08, 2008 5:38 pm
Hi,
Body lift wont help a sausage with towing as the tow hitch comes off the chassis.
Suspension lift on a leaf sprung is very easy, just need a set of shackles, size of shackle controls the lift. Of course most folk off roading want extra height so they need the extension on top of normal height and I would recomend for them to buy new leaves too.
If your not going off road, and its sag in the old springs, you may get away with lifting the springs pm Fuddy he has a spare set he may sell. That or get in touch with Milner off road and ask them for a price on new springs.
Re: A seris lift by john (smifffy) on Sat Mar 08, 2008 5:40 pm
Re: A seris lift by dickycaz on Sat Mar 08, 2008 5:42 pm
i have just fitted new leaf springs to my truck from milners
suspension leaf spring plus fitting kit and delivery £57.58 each
it was well worth it :twisted: :twisted:
dickycaz
Modifications: 2.3 td lwb
Re: A seris lift by shaz-n-dave on Sat Mar 08, 2008 6:56 pm
shaz-n-dave
Re: A seris lift by john (smifffy) on Sat Mar 08, 2008 7:25 pm
personaly only if it is faulty ie hanging off
plus you would have to find some were to store sparewheel
i tow with mine on ok and ive got an alko 2004 tow hitch fitted to the van and i can hitch up with no problem
Re: A seris lift by Trugga on Sat Mar 08, 2008 8:46 pm
To resolve the problem, you would probably need to replace the rear springs - that should return the rear to the correct (factory) ride height, the frot is easily done with a big spanner (tightening up the torsion bars to the dimension specified in the Haynes manual).
A body lift does just that - lifts the body away from the chassis with the only real benefit being able to fit bigger diameter tyres.
If you replace the leaf shakles, you won't actually be improving the suspension, just adjusting it's ride height. This might make the caravan look level, but you will still be running on worn rear springs.
Re: A seris lift by optima on Sat Mar 08, 2008 8:58 pm
One question regarding ride hight while we are on the subject ....
I have a older series A and has been lifted 2" but I bet I’ve only gone up about 1" from factory height, does anyone have an comments on this one as I was thinking just leave well alone and just upgrade to 3" life or replace the torsion bars and leaf springs then put on a 3" lift.
Also was the odds of snapping a torsion bar if its been adjusted for a 3" lift ????
Photo Gallery Croisiere Blanche 2008 and other stuff http://www.pc-infotech.com
LR Disco TD5 2003
LR Disco 300TDI 1995 my new play toy with far to many mods....
Sorry Fronty now sold :-)
optima
Registration Year: 1992/K
Re: A seris lift by weave67 on Sat Mar 08, 2008 9:23 pm
i been running on a three inch lift for a while now,ive had no problems the ride is firmer but i dont notice it anymore :D
Re: A seris lift by brachunky on Sat Mar 08, 2008 9:28 pm
3 inch suspension lift
31 10.5 Muds
Re: A seris lift by weave67 on Sat Mar 08, 2008 9:32 pm
not that ive noticed i keep a regular eye on my front tyres and i aint noticed any undue wear :D
Re: A seris lift by shaz-n-dave on Sat Mar 08, 2008 10:43 pm
it sounds like i will do rear springs found out from milner £115 inc p&p what about shackles as well as i am ender there would it be worth doing the shocks.
ive got to do the front shocks for the MOTd'oh rear has passed ok main problem is the emisions a little high the guy said it was a exhaust leak but its a brand new exhaust or is a hole else were ie cat downpipe
i dont want to loose frontie i have only had i 1 year and love it
shaz-n-dave
Re: A seris lift by alex on Sun Mar 09, 2008 4:35 pm
If you put new springs in you will want regular shockers, if you decide to fit new ones.
If you add shackles for say a 2" lift you will need +2" shockers, that would also need the front lifting (easy and free) but then the front shockers want swapping to +2" also.
Running lifted with shackles and wound up torsion bars on standard size shocks isnt a bad thing, you just wont have the articulation off road, I wouldnt do one without the other but a few have with no adverse reactions.
Re: A seris lift by shaz-n-dave on Sun Mar 09, 2008 5:41 pm
thanks for all your help and advise many thanks dave :4x4: :drive:
shaz-n-dave
