mechanic wanted:- Hull or nearest 50 miles
Newcastle and Cumbria to to Scottish Borders
Newly acquired M reg 2.0 3 dr seemed to be worth the small amount that I paid for it. This is for road use with ocassional rough track work to transport small amounts of building materials. I'm going to need some new road tyres and also want to get rid of full wraparound front crash bar which I believe is specifically designed to kill children (pushes them under) and also the running boards. My own mechanical skills don't go much further than polishing and topping up.
peterjagger2000@yahoo.co.uk
peterjagger
Re: mechanic wanted:- Hull or nearest 50 miles by dazza on Sat Apr 12, 2008 8:33 am
hi mate some lads in hull might be able to help you out, if not im up in driffield, got a set of steel wheels in back with half decent tyres if your interested
If its clean your not having fun!!!!
UTRINQUE PARATUS
(Ready for anything)
Humber-Yorks 4x4 Response training team HY44
dazza
Modifications: lpg
you on 15" or 16" wheel rims? off to work now so wont be back on till gone 7pm tonight, will check back then. Im in Hull.
Bull bar is only couple of bolts each side, and same with side steps, but might be rusted up, so need a grinder :):)
Pm me your mobile number if you got one, you probably seen me driving bout Hull allready, you cant miss me :D :D :D
Member no. 705
marlbororman
Return to North of England
