HELP!!!
Somerset to Hampshire
Weymouth Portsmouth Southampton Basingstoke Poole
HELP!!! by Dan_Large on Mon Jun 23, 2008 3:45 pm
My fronty seems to be dieng slowly and painfuly, it stated as a small rattle coming from underneieth so i had a wee peek and relised thet my throttle modulator thingy for aid in starting in cold weather the small vacumm pipe had come off at a closser look the nipple has corroded away so i tied the pipe back for now.....
The rattle started to turn into a clunk on the way home from a trip to birmingham every time i changed gears, thought to myself if i can just make it to chievly service station ill have a look. i got there and it wasnt doing it any more and couldnt find anything wrong.. carried on and then i started to get a real harsh vibration... then as i was trying to head for sutton scotney services a massive bang shook the car and i had lost all drive... got out and the u.j joint had sheerd causing the prop to damage as it hit the tarmac on the A34 causing damage to the prop. vauxhall dont stock and cant get hold of any of these parts and no where seems to have on in a breakers yard in hampshire and dorset can some one pls help!??
also on the way up to birmingham my powersteering idler pully the bearing collasped but thats cool ive sorted that but even vauxhall wanted £150 for that
Largester
2.8 TDI SWB
Dan_Large
Re: HELP!!! by Red Oktober on Mon Jun 23, 2008 4:01 pm
south wales props do the uj ...and i believe can make you another propshaft .. http://www.southwalesprops.com/
Re: HELP!!! by Sir-Doris on Mon Jun 23, 2008 6:08 pm
Heaps of propshafts on ebay at the moment and www.milneroffroad.com do UJ's and here is a link to UJ's on ebay:
http://cgi.ebay.co.uk/ws/eBayISAPI.dll? ... :IT&ih=020
Item No: 300191513504
Re: HELP!!! by frontydan on Mon Jun 23, 2008 8:50 pm
Try the flea bay shop.... firstfrontera.
i have used him a few times and i feel that he is quite reasonably priced too. Hope this helps.
Dan
Member number 4669
frontydan
Bill
Bill
Vehicle Name: The bus
Body lift, 2".
3" suspension lift.
Blue LED dash conversion.
Waffle boards x 2.
AVM Manual locking hubs.
De Catted..... 'Cos i can !!!
Stickers akimbo.
To Follow...........
Re: HELP!!! by rangaKoo on Mon Jun 23, 2008 11:29 pm
Look for a breakers yard just outside of Andover (can't remember their name off the top of my head) They have 3 Sports and 1 LWB at the moment.
They'll have your prop shaft, and to be honest the Uni-Joint is easy as anything (p.o.p) to get... Camberley Auto Factors keep them, and if not them, try Auto-Care in Bordon (they'll deliver to a mechanic in the local area, if not they can probably post it to you after a phone order). It took me only one phone call to have a UJ!! (If you some how can not get one from Camberley or Autocare then try AutoVaux (try google) and they'll have it in stock and will post it out).
If you've still got problems then PM me and I'll send you my mobile number. Can give you a lot more info over text...
If you can't find the breakers yard outside of Andover ring Blackbushe Motors, Yateley, ask them, also try Aldershot Car Spares, they probably have it in stock as well..
Good luck,
Si
rangaKoo
Re: HELP!!! by PaulS on Tue Jun 24, 2008 9:02 am
I know they are not so local, but maybe worth calling them:
http://www.autopropuk.co.uk/
Proud to be Response Member of:
[/color][/b] Image
1994 Frontera Sport in Flame Red 2.0i 8v
PaulS
Modifications: 2" suspension lift, M/T Duelers, Midland Alan 78 Plus Multi CB radio, personalised dents and some rust here and there :)
Return to Southern England
