Frontera Technical Support • View topic - hi guys just joined
hi guys just joined
hi guys just joined by kev 1 on Wed Jun 13, 2007 9:04 pm
kev 1
by fuzion on Wed Jun 13, 2007 9:07 pm
by **ROB** on Wed Jun 13, 2007 9:08 pm
hi kev welcome to the forum :wink:
You've come to the right place to help out with you're problem, have a look through this 2.3 Diesel Section
Hopefully there will be an answer to your problem posted up but if not post it and we'll try and help to the best of our abilities :wink:
Cheers Rob
**ROB**
Vehicle Name: THE HULK
Modifications: 3.1TD CITATION TROOPER
Standard apart from BF Goodrich A/T's
by TheBig-D on Wed Jun 13, 2007 9:10 pm
Welcome to FOG. :D
TheBig-D
Re: hi guys just joined by **ROB** on Wed Jun 13, 2007 9:13 pm
**ROB**
by barryc28 on Wed Jun 13, 2007 9:17 pm
Fronty2
2.8tdi n plate swb
white
flappy paddles removed
Es9000 +2 shockers
barryc28
by bobbinsjob on Wed Jun 13, 2007 10:00 pm
by gotafrontera on Wed Jun 13, 2007 10:17 pm
2L SWB 2" lift 31/10.5/15 MT's 12000lbs Winch
gotafrontera
by Red Oktober on Wed Jun 13, 2007 10:22 pm
by gotafrontera on Wed Jun 13, 2007 10:23 pm
gotafrontera
by Trugga on Wed Jun 13, 2007 10:49 pm
Welcome Kev 1
The issue you described, to me sounds like either a warn wheel bearing that needs tightening or replacing or possibly a warn steering/suspension component (ball joints or track rod end)
Grab a wheel at the top and push/pull it to see if you can feel any play. Then do the same holding the front and back and try to steer the wheel each way.
Any knocking should become apparent.
To diagnose further, get a mate to (carefully) grasp each suspension component in turn as you carry out the above tests - they should "feel" which part is knocking.
I hope that helps
by kev 1 on Wed Jun 13, 2007 11:04 pm
kev 1
by Reeco on Fri Jun 15, 2007 6:45 pm
Reeco
Return to New Members
