Frontera Technical Support • View topic - hi all
hi all
hi all by kickingriffin on Fri May 04, 2007 1:26 am
kickingriffin
by **ROB** on Fri May 04, 2007 6:23 am
**ROB**
by Red Oktober on Fri May 04, 2007 9:00 am
Hiya mate ....Welcome
your tyre size limit is 31" on a standard setup....suspension lifts are reletively easy to do on your 2.3 :D
as for snokels .....there are a few peeps who have go down the "home made B&Q jobbies"
but theres also a couple on here who have proper "safari" type snorkels...take a look at this modded sport for insperation Clicky Here this guy owns his own modding buisness (check out his webstie)
some of us heve gone down the "extended air intake route" this being hidden under the bonnet ....
Pics "borrowed" from this thread
http://fronteraowners.co.uk/v-web/bulle ... sc&start=0
Hope this helps 8)
by Drift on Fri May 04, 2007 9:18 am
O look my car :D
Hi and welcome to the forum :D
Skype Username:
by Red Oktober on Fri May 04, 2007 9:19 am
hi all by kickingriffin on Fri May 04, 2007 10:54 am
cheers guys thats a big help, im gonna try sort out the rev counter and oil pressure gauge as there not working, and try find out were the missing pipes are ment to go what are missing (like a mechnical fuel pump on a astra by the oil pressure sender) then ill crack on with the snorkal.
also noticed it hasent got a guard covering the sump, is it ment to have one? do thay do one that its a direct bolt on jobbie or will i need to make one?
cheers guys
kickingriffin
by Drift on Fri May 04, 2007 11:01 am
It should have a sump bash plate, best checking local scrappers, its a neccesity when going off road :wink:
Skype Username:
by kickingriffin on Fri May 04, 2007 11:10 am
is there any were i can get a free frontera manual download???
im a little worried to all the missing parts,lol
it has a little guard just under the bumper but dont cover the sump ect.
kickingriffin
by Drift on Fri May 04, 2007 11:13 am
It should be in two peices going back to the gearbox :wink:
A Cheap Haynes mannual would be your best bet
Skype Username:
by kickingriffin on Fri May 04, 2007 11:26 am
sweet! ill go halfords and get a manual and ill grab some new oil and filters ect while im there.
what engine oil do i need ?
ill change the desiel filter and ailr filter and oil filter, is there any think else i need to change??
kickingriffin
by kickingriffin on Fri May 04, 2007 11:34 am
underneith next to the oil pressure sender theres like a mechnical pump with 2x out lets any one know what its ment to be for?
kickingriffin
by fuzion on Fri May 04, 2007 6:54 pm
by kickingriffin on Fri May 04, 2007 8:49 pm
kickingriffin
by Reeco on Fri May 04, 2007 9:01 pm
Reeco
Return to New Members
