Frontera Technical Support • View topic - Hi
Hi
Hi by Mark_Reed on Thu Oct 13, 2016 10:25 am
New to the forum and the frontera!
Wanted one for a while now so treat myself.
So thought I would say hello.
Mark.
Mark_Reed
Re: Hi by stretch on Thu Oct 13, 2016 11:07 am
Welcome to fog. What one did you get.
Re: Hi by Mark_Reed on Thu Oct 13, 2016 11:20 am
Hello mate. I orginal wanted a 3.2 petrol but I ended up with a 2.2dti and to be honest I love it and not a slow as I thought. It's a 52 reg olympus:)
Mark_Reed
Re: Hi by stretch on Thu Oct 13, 2016 11:40 am
The 3.2 is quick but thirsty, enjoyed my dti until the pump died.
Re: Hi by Mark_Reed on Thu Oct 13, 2016 12:10 pm
I have read loads of info on pumps dieing. People say it's due to running out of fuel or running it low. This true?
Is this a problem on all diesel dti ? Are pumps cheaper to buy these days?
Cheers :)
Mark_Reed
Re: Hi by RatCav on Thu Oct 13, 2016 12:37 pm
Wotcha!
The fuel helps lube the pump, so no fuel .. no lube .. that causes wear on the internals. Another potential cause is the heat of the engine frying the electronic componentry in the pump. I have often considered a Dti and then seeing if a heat shield could be made to go between the engine and pump to help protect it.
Re: Hi by stretch on Thu Oct 13, 2016 1:05 pm
Re: Hi by Mark_Reed on Thu Oct 13, 2016 6:17 pm
Thanks mate. Well fingers crossed. It has 94k on now and seems fine but you never know.
If it goes I will try and source a recon one if possible.
Mark_Reed
Re: Hi by dave1966 on Thu Oct 13, 2016 11:29 pm
Hi and welcome to the wonderful world of fog.
R.I.P Sable!(2005 to 2013)
dave1966
Re: Hi by Mark_Reed on Fri Oct 14, 2016 2:28 am
Thanks dave!
A heat shield maybe a good idea then RatCav, will look into that.
Thanks for the welcome lads.
Mark
Mark_Reed
Re: Hi by dave1966 on Fri Oct 14, 2016 11:09 am
Your welcome.
dave1966
Return to New Members
