Hello from Billericay
Hello from Billericay by BillericayMG ZT on Sun Oct 02, 2016 8:40 pm
Frontera Sport 2.0 1991 on a "J". I've taken on this car now as my mum has decided not to drive anymore. It's been unused for a year and now needs to be used again. It's too good to let go and has incredibly low mileage with some years less than 200 miles between MOT's. Looking forward to using it as an occasional driver, keeping mileage low and maintaining its excellent condition. Hope to meet other enthusiasts and owners along the way :D
BillericayMG ZT
Re: Hello from Billericay by andytats on Sun Oct 02, 2016 8:51 pm
Hi and welcome to the world of fog
Re: Hello from Billericay by BillericayMG ZT on Sun Oct 02, 2016 9:04 pm
Thanks andytats. Seen quite a few Fronteras as late and they still look good, purposeful and stylish. I have to cover many miles for work and use my daily drive ZT for that but, will include some regular use in the Frontera as this will keep it in good order.
BillericayMG ZT
Re: Hello from Billericay by stretch on Sun Oct 02, 2016 9:49 pm
Hello and welcome to fog.
Re: Hello from Billericay by BillericayMG ZT on Wed Oct 05, 2016 8:06 am
Thanks Stretch. Much useful information here which is going to make my work easier to maintan the Sport in good order.
BillericayMG ZT
Re: Hello from Billericay by RatCav on Wed Oct 05, 2016 9:59 am
Wotcha buddy. The old 2.0 Sports are cracking. Old school making them tough little things.
Re: Hello from Billericay by BillericayMG ZT on Wed Oct 05, 2016 9:16 pm
Thanks RatCav. Agree there it is a tough vehicle. Looks good and chunky too!
BillericayMG ZT
Re: Hello from Billericay by dave1966 on Thu Oct 06, 2016 12:07 am
Hi and welcome to the wonderful world of fog.
R.I.P Sable!(2005 to 2013)
dave1966
Re: Hello from Billericay by BillericayMG ZT on Thu Oct 06, 2016 10:04 pm
Thanks Dave. :D
BillericayMG ZT
Re: Hello from Billericay by Retro Pedro on Sat Oct 08, 2016 7:12 am
Hi and welcome aboard and nice to read that one of the original Fronteras is going to be kept alive.
A real bonus that you know the history of your motor. The 2 litre engine, which is the C20NE was basically the same lump used in the Carltons and Cavaliers from that era with a different sump and oil pick up to get around the front axle found on the Fronty. I know that when I used to run an 89 Cavalier one of the things I used to have to keep an eye on was the basic recycling system getting blocked up with gunk. This is the gauze square filter that fits in the top of the rocker cover and the rubber hose that fitted onto a metal pipe that went back down to the sump. IIRC this was the basic system that would have been employed for burning of excess gases before the invention of the EGR valve. I found keeping the filter and pipe work clean used to help the engine run smoother.
The other thing is the timing belt. I'd put money on it your original Fronty will have the shorter timing belt that was tensioned on the waterpump. Vauxhall did change that configuration when they introduced a timing belt tensioner relatively soon after the Fronty was launched. The easy way to tell is if the top timing belt plastic cover is round or flat. The round version is the original waterpump tensioned. Not a problem but just a heads up if you do the belt change to look out for getting the correct kit from the outset.
Anyhow, good on you for keeping one of the original Frontys on the road. Even the newer ones have to fight the baked bean tin convention so good to see what must be quite a rare Fronty alive.
Re: Hello from Billericay by BillericayMG ZT on Sat Oct 08, 2016 8:30 pm
Thanks Retro Pedro for very useful advice. Yes, it is the rounded top timing belt cover. Already joining forum has proved invaluable as did not know of alternative. I'll check the pipes too. Have to carry out a service anyhow as has stood for quite a while with just an odd up and down the drive. It is certainly one of the first and my mum had it on order for seven months waiting for delivery. Remember collecting it from Magnus in Brentwood and looked stunning in silk Violet. Thanks again. :D
BillericayMG ZT
Re: Hello from Billericay by BadBoy on Sun Feb 05, 2017 1:11 am
Billericay - where's that :lol:
Got some old bits and pieces here that you may or may not want if you want to collect from the town area. Having a clear out of the shed half term week so will know exactly what's left. Mostly bodywork bits as I had a 2.8, Haynes manual etc.
Skype Username: paul.bush21
Re: Hello from Billericay by BillericayMG ZT on Tue Aug 15, 2017 10:32 pm
Hi Bad Boy. Sorry not replied earlier as some family illness and bereavement took over normality. Kind offer thanks. Bodywork all good on the Sport and looks terrific when freshly waxed. I'm going to have to replace the fuel tank carrier as this has some rot but is a weak spot I understand. Need to recover roof lining and then it'll be more or less ready for the road. I'm sure you'll move the parts if you haven't already done so but thanks again for offer. The 2.8 a good engine I'd think as the 2.0 8 valve works hard but has a nice sound on idle.
BillericayMG ZT
Re: Hello from Billericay by BillericayMG ZT on Tue Aug 15, 2017 10:35 pm
Meant to add Bad Boy, is yours a red metallic sport a often see this driving around Billericay? :-?
BillericayMG ZT
Return to New Members
