I'm back
I'm back by covertmaniac on Tue Jan 05, 2016 9:26 am
5 years after selling my 2.2 petrol fronty, I've bought a new project.... 2003 2.2 dti olympus for a whopping £300 due to the previous owner putting petrol into it and running the engine till it coughed and spluttered!
Worst case scenario... New pump which I have one on standby hoping I might get away with a tank drain and system flush...fingers crossed.. Other than that it's mint!
Last edited by covertmaniac on Wed Jan 06, 2016 11:05 am, edited 2 times in total.
covertmaniac
Vehicle Name: Leanne
Modifications: Completely standard at the moment... Watch this space
Re: I'm back by yaki on Tue Jan 05, 2016 11:32 pm
Nice one and welcome back
Re: I'm back by covertmaniac on Fri Jan 22, 2016 8:51 am
Update
Well so far, I've drained the fuel, new fuel filter, stripped down the inlet manifold cleaned all the usual gunk out of the manifold... Found the egr was completeley funked up to the point of not working.... Cleaned it and got it working perfectly, checked all fuel lines, injector seals.... All fine, leak off pipes look brand new.... Rebuilt manifold primed pump....eventually got it started although rough. In limp mode with eml on.... Cleaned all connectors, replaced all vac pipes apart from the fiddly one at the back of block.....still the same.... ordered a new map and crankshaft sensor, which arrived yesterday... Changed the map....voila! Running perfect
Now, I'm waiting for a replacement locking nut key, so I can put new pads on, new tyres all round, change the brake fluid as it's looking rather dodgy, general service and she is finally ready for the road.... Car cost 300, total spend on parts including tyres 490... Whopping total of 790.... Not bad for an 03 olympus I think
covertmaniac
Re: I'm back by RatCav on Fri Jan 22, 2016 10:58 am
Good work.
Return to New Members
