Hello everybody picking up my 2.2 lwb frontera tomorrow!
I did own a 2.0 petrol swb for about an hour till it ended up in a ditch. Hopefully this will last longer, anything to look out for on the 2.2 diesels?
Muddyjim83
Modifications: 3" suspension lift and a snorkel
check the 4x4 engages ok, theres a button on the dash which should show a solid green light once its engaged....if it keeps blinking then its not engaged and obviously theres a problem which could be an easy fix by changing the vac pipes but ofc could be something much more serious. get underneath and check the rear chassis crossmember ( its tucked up behind the rear bumper) they are prone to a bit of rust . anything else treat it & check as you would a normal car.
fuel pumps are known to possibly fail which can be caused by running out of fuel so keep it well topped up, they are quite expensive to replace ( especially more so the later registered models )
good luck :thumbup:
Thanks I'll pay attention to those points looking forward to getting dirty again !
Muddyjim83
Return to New Members
