Frontera Technical Support • View topic - Hello but starting on a bad note! :(
Hello but starting on a bad note! :( by wingz123 on Sat Apr 12, 2014 8:36 pm
Evening all,
I currently own a 2.0 SWB Frontera on an N plate....94/95 I believe....1st Generation either way.
Currently got a few issues with her which I'll post about in the relevant section(s) but thought I'd say hello! I am in Westbury, Wiltshire and you know what that means........Salisbury Plains are on my doorstep!....and that means tank tracks! :)
So hoping to learn more about the truck and pick up some tips on some cheap mods re off-roading as that will be her sole purpose!
Thanks,
James
wingz123
Re: Hello but starting on a bad note! :( by 4x4 bobby on Sat Apr 12, 2014 9:17 pm
Hi James and welcome to the forum. I have had 2 swb's and they to me are great vehicles offroad. Due to illness i have had to calm down so now have a 2.2 DTI lwb which i still love. I hope you get as much enjoyment as i did. :thumbup:
Re: Hello but starting on a bad note! :( by snapper on Sat Apr 12, 2014 9:32 pm
Welcome to the forum James, you mentioned SPTA, I've had a few fun moments on that in the past!
Re: Hello but starting on a bad note! :( by wingz123 on Sat Apr 12, 2014 9:38 pm
Thanks Gents,
Not sure if I posted in the correct section (forgive if I have) here is my thread....
viewtopic.php?f=15&t=56998
wingz123
Re: Hello but starting on a bad note! :( by snapper on Sat Apr 12, 2014 10:25 pm
Re: Hello but starting on a bad note! :( by bobbinsjob on Sat Apr 12, 2014 11:27 pm
Welcome to the madhouse buddy
Return to New Members
