Frontera Technical Support • View topic - dti 2.2 olympus
dti 2.2 olympus
dti 2.2 olympus by matt_olympus on Tue Apr 24, 2012 10:54 pm
hi, im matthew from south wales, merthyr tydfil to be exact. Just bought a lwb olympus 2.2 dti
unfortunatly i had a issue 12 miles from picking up, limp mode and error p0234, turbo over boost
hope this isnt start to an end
matt_olympus
Re: dti 2.2 olympus by Dannyboy on Tue Apr 24, 2012 10:57 pm
Least it wasnt the fuel pump mate!! hope you checked it has had it done!! :shock: . Welcome to the gang mate! :wave:
Re: dti 2.2 olympus by matt_olympus on Tue Apr 24, 2012 11:08 pm
what should it have had done, starts ok, pulls like a train in all gears untill 5th about 60mph, if u floor eml come on.
im gonna check all vac pipes tomorrow. fingers crossed.
matt_olympus
Re: dti 2.2 olympus by 4x4 bobby on Sat Apr 28, 2012 8:36 pm
Hello Matt sorry not said hi before, Welcome to the forum mate. I hope you get the information you need.
Re: dti 2.2 olympus by matt_olympus on Mon Apr 30, 2012 5:48 pm
thanks :D
matt_olympus
Re: dti 2.2 olympus by Dannyboy on Mon Apr 30, 2012 5:57 pm
Return to New Members
