Frontera Technical Support • View topic - howdy
howdy
howdy by Gazeddy on Sat Feb 05, 2011 1:11 pm
hi im gaz from wigan. im going looking at a fronty tomorrow. what should i be looking for its a 2.5 diesel
thats the listing
http://cgi.ebay.co.uk/1997-VAUXHALL-FRONTERA-TD-BLUE-/220734243763?pt=Automobiles_UK&hash=item3364c943b3#ht_1408wt_1139
Gazeddy
Vehicle Name: gazeddy
Skype Username: gazeddy
Re: howdy by dave1966 on Sat Feb 05, 2011 1:22 pm
Hi and :welcome: to the land of FOG. :lol: Sorry,I cant help you with info on the 2.5 but someone will give you info on the 2.5. If thats the one your going to look at it looks good bud.
R.I.P Sable!(2005 to 2013)
dave1966
Re: howdy by Rifleman on Sat Feb 05, 2011 1:36 pm
Hi, firstly welcome to the mad world of FOG.
When checking the car, there are a number of things that are different from the other models.
You must first be aware that the 2.5 is completely cableless, so the ECU operates everything including the throttle.
Check for sideways play in the viscous fan hub (with engine off obviously) :wink:
This is a common fault.
Check for any obvious oil / water leaks around the engine and cylinder head.
Make sure all the levels are correct and the fluids look clean.
Does it have a service history? Should be serviced every 5000/6000 miles.
Check that it starts ok from cold.
When road testing, make sure it revs over 2000rpm when under load. If it doesn't, it will be in limp mode as there will be a fault.
Normally this has to do with the number 1 injector which has a sensor built into it, and is quite a common fault.
The engine should pull very well as they are powerful lumps.
Apart from these things, check everything you would normally check on any other vehicle.
Oh, when you start the engine, dont use the throttle, and allow to idle for a few seconds before touching the throttle.
Same when switching off, leave idling for a few seconds. This is because the turbo and the fuel pump need to be lubricated.
The oil has to get to the turbo before it winds up, and down.
The pump is lubricated by excess fuel, and it will be a very expensive mistake to forget this.
Good luck with the car, hope you get it.
Re: howdy by Gazeddy on Sat Feb 05, 2011 1:47 pm
should have mentioned im a ford tech. fly by wire is nothing new to me thankfully. thanks for the pointers on the engine specifically. can the viscous fan be replaced with an electric one easily. is there a 16 pin dlc or is it vaux specific on this year
Gazeddy
Re: howdy by Rifleman on Sat Feb 05, 2011 2:07 pm
Re: howdy by 4x4 bobby on Sat Feb 05, 2011 10:05 pm
Hi mate and welcome to the forum!!!!
Re: howdy by Sir-Doris on Sun Feb 06, 2011 3:50 am
Hi and Welcome to FOG! :D
Re: howdy by Gazeddy on Sun Feb 06, 2011 10:06 pm
didnt get it. all was looking well until the road test. 2nd gear syncro gone im not paying that kind of money for a car needing a box rebuild
Gazeddy
Re: howdy by horses45 on Thu Feb 10, 2011 5:50 pm
Hi and welcome to the forum :D
Return to New Members
