Just Joined
Just Joined by Jester on Fri Nov 26, 2010 12:09 am
Hi all,
I've got a 2.2 Dti Olympus on a 53 plate that i'm preping for its MOT, had the car from new and thinks its great (not impressed by previouse work done at Vaux dealer so now do as much as I can myself) got a few problems I need to tackle so turned to the internet for help. Happened upon this site and found some realy usefull info already.
My main outstanding problem now is the dreaded ABS light on the dash. I've cleaned the sensors and sensing rings at the front end and while I had the breaks apart to replace pads and scim the discs. The light is still on and the ABS not working. Does the fault have to be cleared with diagnostic tool or will the light go off when I've cured the fault (dont want to start disturbing wiring to check sensors untill I know if this is the case).
Any advise greatly appriciated,
Jester
Re: Just Joined by andysd1 on Fri Nov 26, 2010 12:16 am
hi and welcome,
there is no harm in trying to clear the codes
Re: Just Joined by Roo on Fri Nov 26, 2010 7:46 am
Hi and Welcome to the wonderful world Of FOG :D
Enjoy and good luck with the MOT :D
Roo :D
Re: Just Joined by N1ova on Fri Nov 26, 2010 10:26 am
Hi and welcome to fog :D
N1ova
Vehicle Name: Blue flash
Re: Just Joined by hobsey on Fri Nov 26, 2010 11:15 am
:welcome:
hobsey
Vehicle Name: Fanny
Modifications: Air freshener
HD Trooper rear coils
2" coil spacers
265/75/16 Fedima Frontieras
Recovery shackle
Magnamount Aerial
Re: Just Joined by Wolfie666 on Fri Nov 26, 2010 11:32 am
Welcome to the madness of F.O.G........ :axe: :axe:
Wolfie666
Model: 2.2i Sport Olympus 3dr
Modifications: None so far
2.2 LWB on a T-Reg
Having a 2.8 fitted which will hopefully be finished fairly soon
Re: Just Joined by 4x4 bobby on Sat Nov 27, 2010 4:54 am
Hi mate welcome to the forum.
Re: Just Joined by horses45 on Sat Nov 27, 2010 9:09 am
Return to New Members
