Frontera Technical Support • View topic - newbie member
newbie member
newbie member by tonydebs on Thu Sep 16, 2010 5:08 am
Hi every1 i am after some advise on the 2.5 tds 1998 lwb i am considering what are they like too run and also what should i look out for thanx
tonydebs
Re: newbie member by horses45 on Thu Sep 16, 2010 8:55 am
well first of all wecome to the group and as for the 2.5 i loved mie and regret getting rid of it but the only problem i had was my number 1 injector but apart from that i loved mine
Re: newbie member by Sir-Doris on Thu Sep 16, 2010 9:47 am
Hi and Welcome to FOG! :D :D :D
The 2.5 is a reliable motor. It shares running gear (Brakes, steering, drivetrain etc) with other models of a similar year.
Engine wise the only 3 things to watch out for are the number 1 injector with built in sensor, the viscous fan coupling and turbo gaskets.
Gaskets are easily available and inexpensive.
No 1 injector can be relatively expensive, around £200 if I remember correctly.
Viscous fan clutch is no longer available from VX but a readily available alternative has been sourced quite cheaply.
Re: newbie member by Rifleman on Thu Sep 16, 2010 9:52 am
Welcome to FOG mate.
The 2.5 is a great model, the thing that is different from all the others is everything is controled by the ECU. Even the throttle, so no cables.
Where in Scotland are you mate? as there a few members already with the 2.5 who attend our meets.
Plenty help available.
Re: newbie member by tonydebs on Thu Sep 16, 2010 12:50 pm
tonydebs
Re: newbie member by tonydebs on Thu Sep 16, 2010 12:55 pm
It sounds like it is a good model what are they like on mpg for long runs as i do over 400 miles a week, thanx tony.
tonydebs
Re: newbie member by Rifleman on Thu Sep 16, 2010 4:45 pm
Hi Tony, if you get a good one that has been looked after and regularly serviced, you should get in the mid 30s.
I get a good return with mine, but it is well looked after.
Change the oil and filter and the fuel filter every 5000 miles and keep the other levels checked, and the propshaft greased, and you should be fine.
Check for a good service history on the proposed purchase when you go to see it.
Under the bonnet, check how clean and tidy it is and see if there is any side to side play in the fan hub. If there is play, it is on its way out. Dont worry though as we have found a source for a replacement part at a reasonable price.
Also check for play in the steering at the steering wheel, this is common to all models, and is easily adjusted by the adjuster on the top of the steering box.
When you road test it, listen for front wheel bearing hums. Also rattles from the engine bay. These are usually caused by worn idler bearings. Another job easily sorted.
Anything else you want to know, just ask mate.
Re: newbie member by bl4kmist on Thu Sep 16, 2010 5:14 pm
Welcome to FOG M8... I have 2.5 tds and it costs me £80 odd to fill mine n i get 400mls to the full tank.
hope this helps
bl4kmist
Vehicle Name: BlackMist
Modifications: Kenwood Blue-Tooth Stereo..
Kingpin Amazon Tyres..255/65/16
Re: newbie member by Drift on Thu Sep 16, 2010 5:34 pm
Hi and welcome :D
Re: newbie member by 4x4 bobby on Thu Sep 16, 2010 8:55 pm
Hi mate and welcome to the Family thats FOG!!!!
Re: newbie member by tonydebs on Sat Sep 18, 2010 12:29 pm
Thanx for the advice and the welcome guys
tonydebs
Return to New Members
