New member
New member by Gillien on Sat May 15, 2010 6:20 pm
Hi guys(and gals!)
just bought an N reg frontera 2.8 turbo diesel sport between us (Gill and Neil) 183,000 miles on the clock 11months mot and 6 months tax. just for a bit of fun really.
we fancy doing a bit of ( gentle) off roading. its got a clutch problem at the moment. It struggles to go into gear when you first start up. then when you do eventully get it into gear the bite is right down on the floor. it seems to get a little better as it warms up. but the gear change is never great. when you do declutch, but keep it in gear then she creeps forward? holding her on the brakes make sher shudder and reverse is always selected with a loud crunch. but as everythings gets warmer then the gear selection does get better and the creeping when declutched stops.
but having looked about the forums i`ve got some ideas to play with?
maybe we`ll see some of you around once we source some off road tyres and get the clutch problem sorted fully :dance:
Neil and Gill :D
Gillien
Modifications: No mods as such except for larger than standard greenway off road tyres ( and a little cutting back on the wheel arch plastics) yet to make our minds up as to lift the body or not and do the lift business on the suspension
Re: New member by horses45 on Sat May 15, 2010 6:44 pm
Hi and welcom to the forum,im sure you will find the answers for the clutch probs on here or someone will be along soon to point you in the right direction :D
Re: New member by Rifleman on Sat May 15, 2010 6:52 pm
Hi and welcome to FOG.
Try bleeding the clutch first.
Also check the bulkhead around the pedal box to see if has split. (Common fault)
If it has split you will need to get it welded as the floor/bulkhead bends when you push the pedals down.
If they are ok, then it sounds like the clutch is going to need replaing.
Re: New member by vargas on Sat May 15, 2010 7:06 pm
Hi and welcome to FOG :D
vargas
Modifications: Falken Landair/AT 31/10.5/15
Midland 98 plus CB
2" coil lift
Uprated recovery points front + rear
Re: New member by Gillien on Sat May 15, 2010 11:42 pm
Thnks for the ideas guys, i`ll try bleeding the clutch and checking the bulkheads!
i`m hoping to try to get it up to cown leisure near Bacup at the end of june, :party:
Gillien
Re: New member by Alfie on Mon May 17, 2010 8:56 pm
Hello and Welcome to the gang :D
Vehicle Name: Dino
Re: New member by 4x4 bobby on Mon May 17, 2010 11:26 pm
Hi mate and welcome to the forum. Kieth has hit it on the head either split bulhead needs bleeding or new clutch. You could also try the ajuster on the pedel if none of the others proove any good.
Re: New member by Drift on Wed May 19, 2010 8:17 pm
Hi and welcome, :D
Re: New member by actung on Wed May 19, 2010 8:20 pm
welcome to a great site ul find all u need in here :)
only thing about the adjuster is remember uve adjusted it - i done mines and had pedal fully out after welding bulkhead then clutch started slipping on high revs months after but ended up replacing clutch when all i had to do was re-adjust pedal :( costly lesson learned :roll:
actung
Vehicle Name: THE JEEP
Modifications: 17"x8" mb atlanta alloys(think there america) and 255/65 hankook tyres
Region: Northern Ireland
Re: New member by N1ova on Wed May 19, 2010 10:07 pm
Hi and welcome to fog :D
N1ova
Vehicle Name: Blue flash
Re: New member by Gillien on Thu Jun 10, 2010 9:43 pm
well i managed to sort the problem out with the clutch. the bulkhead needed welding and i bled the system as well. then i found that the engine moved when i pressed the clutch pedal. it had a new clutch fitted before i bought it. any way, i put back in the 4 casing bolts that were missing and HEY PRESTO gears!!!
it should be good now , just need to check the condition of the cam belt then of into the wild blue yonder! :D
Gillien
Re: New member by bigdazz on Thu Jun 10, 2010 9:44 pm
welcome along :dance:
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
caterpillar STICKERS
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Re: New member by nitromotor on Thu Jun 10, 2010 11:44 pm
Welcome to FOG
Re: New member by Sir-Doris on Fri Jun 11, 2010 12:15 am
Hi and Welcome to FOG! :D :D :D
Re: New member by bigdazz on Fri Jun 11, 2010 6:25 pm
welcome
lifted +2
hid kit
tow bar
soft nudge bar
AT tyres
LEATHER
ROOF CAGE
LPG MULTI POINT
SIDE STEPS
SUB+1500 AMP
REMOTE START ALARM
RUNNING LIGHTS
SECOND SPARE WHEEL
CD/DVD PLAYER
DOGGUARD
Return to New Members
