window problem's please help
Window Problem by The Captain on Wed May 09, 2007 9:18 pm
Hi
I have a similar problem found its the quadrant has a tooth missing. take the door card off put your hand under the glass and press the up button whilst gently lifting the glass it should go up.
If its not the quadrant it may be the runner has broken away.
Good Luck Regards
The Captain
by bev on Wed May 09, 2007 9:42 pm
also going back to the original thread
On my first fronty ('94 2.3) I had the same problem.
The window fell off of it's runner whilst in the down position.
Door card off, and found the rivets had sheared.
Easy fix, was pop the runner back in with some help from liquid metal.
It held and was still working when I sold the car over a year later.
Liquid metal Rocks!!!
Not a difficult job and could save you ££££'s rather than going to a garage.
Bev.
I'm Back !!!
'98 2.0 SWB Sport Transglobe
Electric Blue
"Rosie II"
bev
by bobbinsjob on Fri May 11, 2007 7:17 pm
I worked as a windscreen fitter for 12 years. this is a common problem. the 2 plastic lugs on the bottom of the glass are glued on and over time the glue releases especially if the glass wasn't cleaned and primed. take the doorcard off then take the vehicle into autoglass or someone like that and they will prime and glue them for next to nothing if anything at all.
It's not worth buying the primers and glue yourself as they are quite expensive and only have an open shelf life of one week.
Return to New Members
