Goooooooood morning mudders
Re: Goooooooood morning mudders by RatCav on Wed Aug 26, 2015 9:39 pm
If you can wait until next week I can pop over and point them out to you. Can also give you a few pointers ;)
Re: Goooooooood morning mudders by Shaggy on Wed Aug 26, 2015 10:05 pm
Mate that would be awesome! :)
I'm in no real rush to do it tbh, the longer I soak everything in WD can only be a good thing right?
Shaggy
Model: 2.2i Transglobe 5dr
Vehicle Name: Dorothy
Modifications: 2' suspension lift
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Bluetooth Sony headunit and uprated speakers
Re: Goooooooood morning mudders by RatCav on Wed Aug 26, 2015 10:43 pm
Yup. What I did was locate the 4 off rear ones and drill a small hole (4mm) above it through the floor and squirt WD40 onto the end of the captive bolts to help it penetrate the threads.
Re: Goooooooood morning mudders by RatCav on Wed Aug 26, 2015 10:55 pm
This should help you find all 12 of them. The back four are definitely captive (screwing upwards) but I have a suspicion the next pair forwards are also. Could be wrong. Also the captive bolts are M10 fine thread .. not the normal coarse thread the rest are.
Re: Goooooooood morning mudders by Shaggy on Thu Aug 27, 2015 8:43 pm
That's a massive help, cheers :thumbup:
Looks like I've located all 12, looking at them i agree the rear 6 are captive. What do I do if I snap one? Or more?? :crazy:
Is there only me and you reading this thread? :silent: lol
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: Goooooooood morning mudders by Retro Pedro on Thu Aug 27, 2015 8:58 pm
Not sure if the LWB A is the same as the SWB A but when I did my SWB I did snap off a captive. I was able to get an open ended spanner inside a box reinforcing section onto the nut. That said, I did end up having a different approach and cut a hole in the floor above the locating bolt. Not a problem for me as my motor is a pure toy but for a decent looking motor like yours, it might be a same to cut a hole in the boot floor.
Re: Goooooooood morning mudders by RatCav on Thu Aug 27, 2015 9:46 pm
Slowley but surely. When I loosened mine off my 1990 Trooper (same layout) I drilled that small hole above through the floor. I ended up with 6 off 5mm holes that are now hidden under the carpet. I soaked and soaked and soaked for a couple of weeks beforehand. When I went to loosen them way before actually doing the lift I initially tightened them by 1/8th a turn, then slowly but steadily undid it. When I felt it binding, I backed it off a turn. Let it settle (and cool down believe it or not) and then went at it again. Patience is the key. When I removed the two captives furthest forward the unthreaded shank was half the diameter due to corrosion. If I hadn't taken my time it would of surely snapped.
If you snap one then there are a few options. Drill it out from above, weld a nut on and go again (often the heat from welding helps break the binding. Nothing to panic over .. though best to avoid it if possible. The front 6 are not an issue. If you snap one then you can just butcher it out as they are nut and bolt jobbies. You are replacing them anyway.
Re: Goooooooood morning mudders by Fatbaz on Fri Aug 28, 2015 1:26 pm
Hi
Regarding the lift, nothing needs extending for a 2 inch lift, but to be safe when doing the lift unclip the brake pipes from the inner wings, slacken off the hose connecting the tank to the filler neck and remove the rad cowl. After completing the lift refit all but the cowl. On mine I binned the cowl and viscous fan and fitted 2x 10inch electric fans direct to the rad, wired and piped accordingly.
as for the rear body bolts, had the same fears as you and succeeded in snapping the first bolt I touched with a socket, head snapped off it. Once the body was lifted I managed to get stilsons/grips to the shaft of the bolt between body and chassis.
difference between yours and mine is mine is a A series 2.8 SWB so you have a few bolts more and the body is heavier. I've got a set of front bumper irons already modded for a 2 inch body lift if your interested, I built a winch bumper for mine so don't use them. Got the wrap around bull bar to match the bumper as well.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
Re: Goooooooood morning mudders by Shaggy on Fri Aug 28, 2015 9:33 pm
Thanks for the info Chaps :thumbup:
Well, curiosity got the better of me tonight. I was itching to try and SLOWLY unbolt one... just one, just to see how easy (or hard) it would be :crazy:
Armed with a drill, box of good drill bits, and a tap and die set ready for a long night, and a pot of grease 'just in case it came out ok' I started on the o/s/r and.... No dramas! Wound it out a bit, back a bit, out a bit more and so on till I could take it out by hand :clap: Greased it up and put it back in and did the same with the next, and the next. All 6 came out with no worrys what so ever :dance: :dance: :dance: Happy days indeed :party:
I'll just cut the middle 2 out on both sides and with any luck the fronts will unbolt easy enough, or snap and save me the hassle :lol:
Stuart, I've got an electric fan on mine not a viscous one so I don't need to trim the cowl :wink: I might have to twist/trim the lower hose though.
Just a thought... if the bottom of the rad sits on the chassis (I think) and the top is held in place by the bracket on the body, whats going to hold it in place once I've lifted it?
'Might' lift it tomorrow afternoon after work, failing that i'll make a start on Tuesday night :excited:
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: Goooooooood morning mudders by Retro Pedro on Fri Aug 28, 2015 9:43 pm
Don't think you'll have any dramas with the rad. IIRC the rad fixing are attached to the bodywork.
That's why the cowl as to be cut on the viscious fan versions. The body goes up and the viscious fan, being bolted onto the engine, stays where it is.
Re: Goooooooood morning mudders by Shaggy on Fri Aug 28, 2015 9:57 pm
:thumbup: :thumbup: :thumbup: :thumbup: :thumbup:
Am I right in thinking the front bumpers attached to the chassis? So in theory I could leave it on for now and lift it to suit in due course? I don't like the idea of running without it, not that it really does anything but it just looks neater lol
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: Goooooooood morning mudders by Shaggy on Sat Aug 29, 2015 8:07 pm
Fitted my lift kit today, I don't know what I was panicing about tbh :lol:
Bumpers looked stupid, especially the front :sick: :sick: :sick:
So I little bit of fettling...
Dixie horns are for 'off road' use only officer :wink:
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: Goooooooood morning mudders by RatCav on Mon Aug 31, 2015 12:58 pm
Nice ;)
Re: Goooooooood morning mudders by Shaggy on Mon Aug 31, 2015 5:55 pm
Cheers RatCav :thumbup: Only thing is, I wanna go higher now :lol:
I've redrilled both bumpers and put them back on but whilst they were off I jet washed the underside of the body and the chassis rail. I then wire brushed it and waxoiled it all bar a small section that needs welding... properly
Someones done a top quality patchwork repair there :lolno:
I also found why we often smelt fuel at the rear, the smaller of the 2 inlet pipes has a nice split in it (In the rubber hose) :shock: It's on top of the pipe so isn't leaking as such but i'll replace that tomorrow as I know theres some hydraulic hose the same diameter at work :wink:
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: Goooooooood morning mudders by RatCav on Mon Aug 31, 2015 6:27 pm
Job done. The tank is far easier once you have the body lifted.
Saw you today and waved. Was in a little Silver Golf as you were heading out of town towards lostock hall ;)
Re: Goooooooood morning mudders by Shaggy on Mon Aug 31, 2015 6:51 pm
Baaaaaaaaaaaaaaahahahaha, I've been racking my brains all day wondering who that was!!!! :lol: :lol: :lol:
How'd the Fronty look???? :4x4: :lol:
Would have been a tank drop job to get at that pipe, and I doubt id have found it if it wasn't for lifting it! I also found a very wet muddy rag on top of the tank too haha
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: Goooooooood morning mudders by RatCav on Mon Aug 31, 2015 6:53 pm
Looked good mate. Definitely looking the part now ;)
I was just back from the Trooper owners club annual. We found a pair of boxer shorts hanging off one guys axle after he went through a mud pit :sick: :sick:
Re: Goooooooood morning mudders by Shaggy on Mon Aug 31, 2015 7:08 pm
Oooooooooooooooh nice! :sick: :sick: :sick: Hahaha
Cheers pal :thumbup: Its where I want it looks wise now, just to get it 100% mechanically sound and i'll be happy :dance:
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: Goooooooood morning mudders by Shaggy on Tue Sep 01, 2015 10:15 pm
Popped out to the shop earlier and 'just so happened' to have a camera in the car. One of the kids but hey, although trying to look cool whilst taking photos with a big chunky 'KiddyZoom' cameras near on impossible :lol:
Shaggy
2' body lift
265/75/16 Mud tyres
Rock sliders
Modified bumpers
Re: Goooooooood morning mudders by aredee on Tue Sep 01, 2015 10:39 pm
nice job looks good want to do mine but a bit nervous if i cant complete or something breaks
aredee
Vehicle Name: Bubbles
Return to New Members
