UK Byways map
UK Byways map by BadBoy on Sat Feb 02, 2013 9:07 pm
Came across this website earlier today.
http://bywaymap.com
Looks like it's still very much work in progress as it would appear 100's of lanes are missing and it should in no way be used to confirm that a lane can be driven as it shows lanes I know have permanent TRO's as BOAT's, but it's a good start and could prove to become an excellent aid for planning days out.
Please remember to refer to local/county councils or highway authorities for current TRO information before you set out :wink:
Skype Username: paul.bush21
Re: UK Byways map by James Bass on Sat Feb 02, 2013 10:58 pm
:well done: :ggod post:
Nice one Paul!
Re: UK Byways map by Fatbaz on Sat Feb 02, 2013 11:37 pm
If you haven't got Memory Map to reference you can also try "where's the path", http://wtp2.appspot.com/mobile/mobile.htm as this has the O/S maps for the whole of the UK same as Memory Map.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
