4wd can anyone clarify for me?
4wd can anyone clarify for me? by liamholly on Sun Feb 01, 2009 2:51 pm
Hi. all. I have been reading the vauxhall drivers manual and was just wondering if anyone can tell me if 4wd has been selected when stuck in snow, could i then go back into 2wd and continue my journey with the automatic hubs locked or would i need to reverse every time i have used 4wd? Any advice as always would be appreciated. Thanks.
liamholly
Re: 4wd can anyone clarify for me? by tws7501968 on Sun Feb 01, 2009 3:01 pm
tws7501968
Model: 2.2i Transglobe 5dr
Re: 4wd can anyone clarify for me? by john boy on Sun Feb 01, 2009 3:06 pm
Yes you can but i wouldn't advise it for long distances, i know others leave them locked in when green laning but i do back up and unlock them :wink: i tend to find even with it back in 2wd i get some wind up in the transfer box.
Re: 4wd can anyone clarify for me? by alex on Sun Feb 01, 2009 3:46 pm
As above. Mine was 2wd and locked (manual hubs) I got some real unpleasant noises and some drag.
Re: 4wd can anyone clarify for me? by Drift on Sun Feb 01, 2009 9:11 pm
Ive drove 130 miles at motorway speed with autos and later when I fitted manuals with no problems at all..I keep forgetting to unlock them :oops:
They will cause a bit of drag and possibly use a tad more fuel but shouldnt affect the drive train as no power is going through the drive shafts or prop, just the drive shafts free wheeling in with the hub :wink:
Re: 4wd can anyone clarify for me? by furio on Sun Feb 01, 2009 10:53 pm
Always unlocked mine at the end of each section when out laning, hope this helps.
furio
Manual Cooling Fan Switch
Old Man Emu Suspension lift
Roof lights
Raised Axle Breathers
Re: 4wd can anyone clarify for me? by boybilbo81 on Sun Feb 01, 2009 10:59 pm
Me too, I like to back up before I move on, takes no time at all.
Image Image
boybilbo81
Modifications: C75 Aluminium Expedition Roof Rack
Front Roof Lights
Rear Work Lamp
Roof Strobes front and rear
Bonnet deflector
2x 18mm Galvanised bow shackles on the front
Insa Turbo Traction Track Tyres
235/70/16
2x CB Radios
PA System
Planning:
2" Body Lift
2" Suspention Lift
Moddified Air intake (not Snorkel)
Re: 4wd can anyone clarify for me? by Drift on Sun Feb 01, 2009 11:04 pm
Tons of info on the 4WD system on the FOG Wiki pages :D
Re: 4wd can anyone clarify for me? by liamholly on Fri Feb 06, 2009 7:44 pm
Thanks everyone. Think I will play it safe and back up. Better safe than sorry.
liamholly
Re: 4wd can anyone clarify for me? by Drift on Fri Feb 06, 2009 10:16 pm
I must like living on the edge :shock: :lol:
Seriously if you forget to unlock I guarantee you wont cause any damage if the mechanism is in working condition.
Just to put forgetful minds at ease :wink:
Re: 4wd can anyone clarify for me? by nitromotor on Sat Feb 07, 2009 12:49 am
You can have the hubs locked full time all the time, no probs.
The front axel, just like the rear has a differentialential.
The role of the diff is to allow the wheels to rotate at different speeds.
The frontera, not having a centre differential between the front and real axel
means that 4WD should only be used when the ground is louse or slippery .
This allows the wheels to slip, allowing for the different speeds of front and rear wheel rotation, (cornering and tread depth etc)
