Frontera Technical Support • View topic - Great Alne Ford WARWICKSHIRE
by fuzion on Wed Nov 29, 2006 1:31 am
by sollihull on Wed Nov 29, 2006 2:19 am
Don't hit the Water at an excessive Speed ...
Keep the Speed up enough to keep the Bow-wave Right in Front of you as the water drops lower right behind it which is handy for the Air intake section in the top of the wheel arch ....
Try not to go alone just in case you have a bad moment and Imitate the HMS Fronteras' we have on here .....
Keep a Can of WD40 Handy in case you need to spray some areas to drive the moisture out ......
ALWAYS Check your Brakes when you've left the water and are a Sensible Distance Away from the ford .......
IF You do start to lose it and float away , KILL THE ENGINE AT ONCE so you don't hydraulik and wreck the Pistons .........
All those are things I have done and Touch Wood .. not come a cropper .
As to the Speed bit , it's a case of Do as I say, NOT as I do lol
sollihull
by fuzion on Wed Nov 29, 2006 7:52 pm
Thanks Steve,
Excellent advice for all us waterbabies. :D
Mat
by Trugga on Wed Nov 29, 2006 9:58 pm
by fuzion on Wed Nov 29, 2006 10:01 pm
by Red Oktober on Wed Nov 29, 2006 11:38 pm
by sollihull on Thu Nov 30, 2006 1:53 am
sollihull
by Drift on Fri Dec 01, 2006 11:10 pm
by Red Oktober on Fri Dec 01, 2006 11:13 pm
by fuzion on Fri Dec 01, 2006 11:17 pm
by Drift on Fri Dec 01, 2006 11:19 pm
by Red Oktober on Fri Dec 01, 2006 11:25 pm
by Drift on Fri Dec 01, 2006 11:27 pm
by Turbochops on Sun Dec 03, 2006 8:37 pm
Turbochops
by Trugga on Sun Dec 03, 2006 8:42 pm
by Red Oktober on Sun Dec 03, 2006 8:45 pm
by Turbochops on Sun Dec 03, 2006 9:26 pm
Turbochops
by sollihull on Wed Dec 06, 2006 11:32 pm
sollihull
by fuzion on Wed Dec 06, 2006 11:42 pm
by sollihull on Wed Dec 06, 2006 11:46 pm
sollihull
