[phpBB Debug] PHP Warning: in file [ROOT]/includes/bbcode.php on line 112: preg_replace(): The /e modifier is no longer supported, use preg_replace_callback instead Frontera Technical Support • View topic - Llangollen run
I won't be going mad Alex, not bothering with the steps or the V, I've done it all with my SWB when it was standard. If you know Whitestones and the wayfarer, then that will give you a good idea what the rest of it will be like. One or two lanes could be a bit scratchy. I'll leave it with you.. Might have a look in on the carwash at the end (level dependent of course)
As if your arm needed any twisting to go laning Andy!! Nice one lads a full house then. Will be good to get out with you again Phil . The start point I'm thinking of llangollen, finish will be corwen or Bala. I'll pm you all the details when I have it sorted sometime next week .
So if i'm right the list now looks like this: Big Red, Weave, Sir Doris, Andy, Alex and Furio, might have to run two groups? Anyone volunteer to lead another group?
