// Frontera Technical Support • View topic - Annual Spanner Party/BBQ 2013 20th-21st July
Re: Annual Spanner Party/BBQ 2013 20th-21st July
Postby Drift on Sun Jul 21, 2013 11:37 pm
:shock:
the new bolt to snap halfway in.
The most expensive bolts in the world :sick: :lol: :lol:
Frank was on a mission though :lol:
Did your turbo pipe hold up okay and did you clean that bloody rad? :roll: :lol:
Postby snapper on Mon Jul 22, 2013 12:20 am
Well, as always a good event well hosted by Chrissy and Bobby, thanks folks. Big thanks to Ian and Ste for getting the rear shocks off the truck and helping to get the new ones in, hours to do 2 shocks... :shock: nightmare... Was good to see old faces again too.
Oh and a well done to the chef (Horses), who made a better good at job killing the burgers than we did on the truck service... Question is, did we put the oil in or not???
Having set off from Bobbies and making a short stop in the caravan place down the road for some van related bits we finally managed to find the CC site we were headed for, after dragging the van down some pretty narrow lanes and then finding the post code on the booking form was ... Well, shall we just say it wasnt the ******* site! Thank gawd we didnt meet anything coming the other way, I was NOT going to reverse back up those lanes!
Postby bobbinsjob on Mon Jul 22, 2013 10:32 am
Drift wrote::shock:
Err the hose sort of did but the turbo didn't. Squirted contents of engine everywhere :'(
Postby jellybaby on Mon Jul 22, 2013 3:12 pm
Maybe rob has a turbo in the shed everything else was there. That shed should be called the tardis .
Vehicle Name: Dotty
Modifications: Err its a discovery
2" lift
265\75 r16 tyres
Winch bumper and steering guard
Heavy duty drag and steering bar.
Postby Drift on Mon Jul 22, 2013 5:25 pm
oops :shock:
Postby snapper on Mon Jul 22, 2013 9:41 pm
Ahh, bad luck there mate, are we now talking about another spanner party to swap the turbo??? Tis simple enough (thread here) once you manage to find another turbo.
You would be looking at anything from £50 for a pre-owned unit up to £550 +/- for a new unit, add to that gaskets etce.
Postby bobbinsjob on Mon Jul 22, 2013 10:55 pm
Well I stripped it all down this evening. Including taking the rad and intercooler off. Split the snail to find only a slight trace of oil in there which I believe is quite normal and the impeller has no play at all and silent bearings. Then I went to remove the turbo from the oil and water feeds and returns to find that the barstuard one to get to on the oil return was already loose. When I got it off it seems someone has already replaced the turbo but put the wrong sized bolts in the flange and tried to pack them out with washers. It has vibrated loose so all the oil under pressure has come out at the gasket.
As I am on nights tonight i will take the opportunity while the engine bay is quite empty to give it a damn good cleaning tomorrow and put it all back together. After I've done an oil filter change. I've also flushed out the rad and cleaned out the intercooler with petrol.
Hopefully it will be a cheap fix and run a bit better too.
Postby 4x4 bobby on Tue Jul 23, 2013 8:08 am
Nice to know its not to serious mate. And make sure you don't go to Hafrauds for the bolts !!!!!!!! :lol: :thumbup:
Postby bobbinsjob on Thu Jul 25, 2013 12:05 am
All done. Oil change as well. No leaks. I re did the hoses with self fusing tape from bnq and they hold a treat.
