part numbers
frontera where it came from how powerfull MPG etc
part numbers by crash_ndie on Thu Dec 20, 2012 1:32 am
found off a site so ....
2866475
Valve spring
Frontera
92-98
2898364
Ball rocker
Frontera
c24ne
92-98
2898618
Rocker nut
Frontera
92-98
3430782
or http://www.vauxhallgreenparts.co.uk/Frontera.html
Gasket, thermostat housing
Frontera
2.4NE
92-98
3456256
Seal ring, fuel injector
Frontera
23TD
92-98
3456257
Injector insulator/seal
Frontera
2.3D
92-98
3471621
Starter, drive gear mounting clip set
Frontera
92-98
5234520
Lifter Valve
Frontera
CIH
8930102
Timing chain
Frontera
C24NE
92-98
8930326
Seal ring, 12x17.2x5
Frontera
2.4P, 2.3D
92-98
8939965
Timing chain tensioner
Frontera
2.4P, 2.3D
92-98
8966222
CIH plastic head screw
Frontera
C24NE
92-98
9005240
Coil single plug type (Delphi)
Frontera
3.2
99-
9114583
Car telephone transformer
Frontera
92-
9117693
Injector washer copper
Frontera
2.2 DTH
9117905
Valve lifter
Frontera
X22XE
92-98
9117905
Valve lifter
Frontera
22DTH
99-
9119514
Fuel injector nozzle
Frontera
2.2dth
99-
9121676
Towing pack
Frontera
99-
9128722
Timing Belt
Frontera
X22XE
92-98
9128722
Timing Belt
Frontera
Y22SE,X22SE
99-
9128725
Timing Belt
Frontera
C20NE
92-98
9128738
Pulley idler timing belt
Frontera
2.2
92-04
9132691
Glow plug controller
Frontera
99-
9135156
Sensor bulb test (BD)
Frontera
99-
9152245
Sensor outside temp
Frontera
99-
9158200
Vac valve boost control
Frontera
2.2D
99-
9192342
Flywheel bolt
Frontera
X22DTH,Y22DTH
99-
9192925
Solenoid
Frontera
23TD
92-98
9195999
Clutch cover assy
Frontera
X22 DTH
99-
9202219
Front cover gasket
Frontera
X22DTH,Y22DTH
99-
9226543
Gasket inlet manifold to head
Frontera
99-
9383689
Injector controller (Delphi 8093836890)
Frontera
3.2
11067361
Bolt, housing to block
Frontera
24NE,23TD
92-98
11072602
Bolt, timing sprocket
Frontera
23TD
92-98
11073981
Tube nut (90121020)
Frontera
C24NE
92-98
11083045
Screw, bracket to cylinder block
Frontera
92-98
11094921
Screw, m8 x 85, compressor to support
Frontera
X2.2DTH,Y2.2DTH
99-
11096531
Washer alloy
Frontera
2.2 DTH
99-
12160244
Air temperature sensor
Frontera
22SE,3.2P
99-
23000508
Wiper motor
Frontera
92-98
24442408
Plug timing chain guide
Frontera
2.2 DTH
99-
24445063
Turbo assy
Frontera
2.2 D
99-
25173828
Injector
Frontera
2.2
99-
72081314
Shock absorber,rear
Frontera
4 dr
92-98
72117661
Rear Shock absorbers
Frontera
2 dr
92-98
72118280
Shock absorber, rear
Frontera
4 door
92-98
90017503
Pipe, water pump to thermostat
Frontera
C24NE
92-98
90018194
Fuel injection pump, solenoid valve
Frontera
2.3TD
92-98
90067918
Thermostat
Frontera
2.4/2.3D
92-96
90105799
Crankshaft spigot bearing
Frontera
23TD
92-98
90108047
Oil pump thrust spring
Frontera
C24NE
92-98
90117054
Radio blanking plate
Frontera
92-98
90118437
"O" ring thermostat
Frontera
92-
90122383
Camshaft bearing no1, standard
Frontera
2.4p
92-88
90122384
Camshaft bearing no2, standard
Frontera
2.4p
92-88
90122386
Camshaft bearing no4, standard
Frontera
2.4p
92-98
90122390
Camshaft bearing, centre No2 .1mm U/S
Frontera
C24NE
92-98
90122391
Camshaft bearing no3, 0.1mmu/s
Frontera
2.4p
92-98
90122392
Camshaft bearing no4, 0.1mmu/s
Frontera
2.4P
92-98
90128081
Bolt shoulder, front to centre exhuast pipe
Frontera
92-98
90136958
Brkt adaptor alternator
Frontera
c20ne
92-98
90136995
Ring gear
Frontera
Manual
92-98
90141496
Dist base cover
Frontera
c24ne
92-98
90156062
Gear timing crankshaft
Frontera
c20ne
92-98
90166629
Fuel pressure regulator, Bosch 0280160221
Frontera
C20NE
92-98
90167851
20A blade fuse
Frontera
92-98
90181010
Headlamp mounting clip
Frontera
92-98
90183135
Head bolt
Frontera
2.3D
92-98
90190983
Water pump gasket
Frontera
2.4P, 2.3D
92-98
90192481
Relay (4 pin white),pressure switch overide
Frontera
for aircon
92-98
90194459
Oil pipe return fitting
Frontera
2.3D
92-98
90196375
Switch stop lamp
Frontera
92-98
90213515
Sensor crank revolution
Frontera
92-98
90220130
Bush, alternator bracket
Frontera
C20NE, 70amp
92-98
90230261
Hose heater
Frontera
92-98
90231113
Fan pully, 4 bolt
Frontera
2.0NE
92-98
90231221
Fan pully, 3 bolt
Frontera
2.0NE
92-98
90231973
Fan support
Frontera
C20NE
92-98
90232732
Engine Speed Sensor
Frontera
c24ne
92-96
90233119
Bush, power steering pump
Frontera
20NE,24NE,23TD
92-98
90233545
Clip header tank
Frontera
92-99
90265150
Clip cowl to rad
Frontera
92-99
90271472
Injectors Bosch (280150725)
Frontera
C20NE
92-98
90271847
Hose water pump distributor
Frontera
2.0NE
92-98
90278413
Brkt block to trans LH
Frontera
2.0, 2.2
92-99
90278414
Brkt block to trans RH
Frontera
2.0, 2.2
92-99
90280885
T piece, heater hose
Frontera
C2.0NE
92-98
90285291
Oil Seal Camshaft
Frontera
92-96
90285592
Fuel feed Hose
Frontera
23TD
92-98
90297940
Injector assy
Frontera
c24ne
92-98
90298172
Head gasket, 1.3mm
Frontera
23TD
92-98
90298326
Spring clip injector
Frontera
92-
90299642
Injector adaptor plate
Frontera
c24ne
92-98
90318942
Switch assy window rear
Frontera
92-98
90321996
Cage, radio ident KG
Frontera
92-98
90323494
Gasket, oil pick up to block
Frontera
2.4P, 2.3D
92-98
90323839
Throtle position switch
Frontera
92-
90324050
Fire ring, exhaust to mainifold
Frontera
2.0, 2.2P, 2.3D
92-98
90325247
Gasket, injector to head
Frontera
2.4P
92-98
90339457
Heated seat switch
Frontera
92-98
90350495
Lambda sensor
Frontera
2.4P
92-98
90350988
Distributor cap
Frontera
C24NE
92-98
90352136
Ventilation hose
Frontera
2.3D
92-98
90352931
V belt 9.5 x 788 pump
Frontera
c20ne
92-99
90353038
Gasket, timing case L/H
Frontera
C24NE
92-98
90353182
Fuel injection pipe
Frontera
23TD
92-98
90353538
Pump Auxiliary Cooling
Frontera
2.3D
92-96
90355463
Switch hood anti-theft
Frontera
92-
90376980
Distributor moisture plate
Frontera
C20NE
92-98
90378651
Relay ECU/Fuel pump
Frontera
92-98
90386023
50amp fuse
Frontera
92-98
90409644
Exh/Man to Head Gasket
Frontera
92-96
90409648
Inlet/exhaust manifold gasket
Frontera
C2.4NE
92-98
90409900
Timing Belt
Frontera
c20ne
92-98
90410741
Valve Stem Seals
Frontera
x22xe
92-
90410813
Exhaust valve
Frontera
16V
92-98
90410813
Exhaust valve
Frontera
16V
99-
90411528
Side cover gasket
Frontera
2.4P
92-98
90411551
Fuel Inj/Rail + Pressure reg & fittings
Frontera
x22xe
92-
90411766
Frontera
c20ne
92-98
90412277
Inlet valve
Frontera
90412459
In/Man to Head Gasket
Frontera
x22xe
99-
90412508
Oil filler cap
Frontera
92-
90442013
Kit screws dist (valeo)
Frontera
c20ne
92-98
90442356
Rotor arm
Frontera
c20ne
92-98
90444861
Head bolt
Frontera
C20NE,X20SE
92-98
90448866
Oil pan baffle plate
Frontera
C2.0NE
92-98
90467195
Hose clamp
Frontera
25TD
92-98
90467195
Hose clamp
Frontera
22SE,22TDH
98-
90467664
Oil filler cap
Frontera
2
92-98
90487723
Head gasket, 1.4mm
Frontera
23TD
92-98
90499198
Timing belt cover gasket
Frontera
X22XE
92-98
90499484
Head gasket
Frontera
X22XE
92-98
90500229
Belt tensioner
Frontera
92-04
90500571
Gasket engine breather
Frontera
92-98
90500696
Timing gear, crankshaft
Frontera
2.2D
99-
90501647
Sump gasket
Frontera
C24NE,23TD
92-98
90502311
Timing chain guide
Frontera
Turbo diesel
99-
90502732
Fuel injection pipe, nos 3 & 4
Frontera
X22DTH
99-
90502753
Rocker, valve
Frontera
2.2D
99-
90502878
Gasket, thermostat housing to head
Frontera
X22DTH,Y22DTH
99-
90506201
Alternator
Frontera
90510153
Airflow meter (90351567)
Frontera
X20SE, X22XE
92-98
90510210
Cooling fan
Frontera
all engines
92-98
90513242
Immobiliser control unit bosch
Frontera
92-98
90513566
Flasher unit
Frontera
92-98
90528598
Gasket,vacuum pump to head
Frontera
2.2 DTH
99-
90530126
Timing belt tensioner
Frontera
x22xe
92-98
90531396
Vacuum pump
Frontera
2.2 DTH
90540188
Frontera
99-
90540270
Frontera
2.8TD
92-98
90541911
Injector " O " ring
Frontera
X20SE,X22XE
92-98
90543014
Relay
Frontera
92-98
90570371
Cam belt
Frontera
C20NE
92-98
90572544
Water pipe, insert to block
Frontera
2.0-2.2P
92-98-
91111612
Jack handle assembly
Frontera
92-98
91115326
Check link pin
Frontera
92-98
91126433
Gasket, exhaust manifold
Frontera
2.5TD
92-98
91126441
Front door upper left hinge
Frontera
all
92-
91129367
Boot liner
Frontera
2 dr
92-98
91132258
Rubber mat set
Frontera
4 door WL4
92-98
91132260
Carpet mat set
Frontera
4 door WL4
92-98
91132379
Carpet mat set
Frontera
4 dr
99-
91132429
Towing electrics pack
Frontera
99-
91140020
Door link,back
Frontera
2 dr
92-98
91140094
Front wing RH
Frontera
4 door
92-98
91140095
Fron wing LH
Frontera
4 door
92-98
91140253
Rear spring shackle plate
Frontera
2./2.4P 2.3D
92-98
91140872
Sump guard
Frontera
92-98
91141773
Exhaust pipe bracket
Frontera
C20NE
92-98
91141793
wheel Arch moulding LH
Frontera
92-98
91141794
Wheel arch spat
Frontera
4 dr
92-98
91141846
Tail gate
Frontera
4 dr
92-98
91142052
Bumper corner, front RH
Frontera
4dr
92-98
91142057
Front door glass, LH
Frontera
92-98
91142062
Power steering pump
Frontera
C20NE,C24NE,23TD
92-98
91142089
Rear door glass, opening,LH
Frontera
4 dr
92-98
91142130
Support front end panel
Frontera
92-98
91142171
Wiper motor cover
Frontera
2 dr
92-98
91142246
Fan belt 9.5 x 880
Frontera
C24NE
92-98
91142392
Header tank hose
Frontera
2.3 TD
92-98
91142533
Rear pillar guard strip
Frontera
4 dr
92-98
91142567
Front bumper bracket, LH
Frontera
92-98
91142696
rubber strip,radiator upper seal for aircon
Frontera
All
92-98
91142882
Mudflap RH
Frontera
4door
92-98
91142897
Weatherstrip, rear door glass channel,LH
Frontera
4dr
92-98
91143065
Tow bar
Frontera
Sport
92-98
91143115
Load compartment guard
Frontera
92-98
91143117
Alarm door lock interface
Frontera
motor&interface
92-98
91143118
Switch, alarm
Frontera
92-98
91143326
Headlamp
Frontera
L/H
92-98
91143343
Rear lamp lens kit, R/H
Frontera
Sport
92-98
91143344
Rear lens, LH
Frontera
4dr
92-98
91143345
Rear lens,LH
Frontera
2dr
92-98
91143569
Washer bottle
Frontera
92-98
91143773
Spark plug
Frontera
C24NE
92-98
91143853
Wheel nut cover
Frontera
92-98
91143912
Front step moulding, rubber
Frontera
4wd
92-98
91143913
Rear step moulding, rubber
Frontera
4wd
92-98
91144107
Foglamp harness
Frontera
92-98
91144207
Oil cooler Hose (790mm)
Frontera
23TD
92-98
91144228
Bolt M6 x 17
Frontera
92-98
91144288
Vacuum pipe
Frontera
23TD
92-98
91144525
pipe condenser to dryer
Frontera
2.0P,2.4P,2.3D
92-98
91144555
Boot/hatch seal
Frontera
2 Door UD2
92-98
91144609
Spare wheel cover, carpet
Frontera
not tailgate mounted
92-98
91144661
Windscreen side moulding,RH
Frontera
92-98
91144707
Heater hose return
Frontera
23TD
92-98
91144725
Check link door Front
Frontera
RV634704-
92-98
91144732
Adaptor, pipe to turbo
Frontera
2.3TD
92-98
91144744
Header tank to water pump hose
Frontera
2.3D
92-98
91144841
Window regulator rear LH
Frontera
4 door
92-98
91144855
Window regulator,LH
Frontera
92-98
91144877
Glass mirror non heated, convex LH
Frontera
manual operation
92-98
91144880
Mirror assembly, R/H,black up to RV643542
Frontera
convex, manual
92-98
91144968
Window lifter control
Frontera
2 Door UD2
92-98
91145123
Heat shield
Frontera
C24NE,23TD
92-98
91145189
Clip, washer hose
Frontera
92-98
91145472
steering shaft, non tilting
Frontera
92-98
91145594
Finisher, 20 mtrs
Frontera
92-98
91145775
Harness, alarm status monitor
Frontera
92-98
91145902
Clip air cleaner to mount
Frontera
92-88
91146643
Door seal
Frontera
91146910
Mounting rubber, lower radiator
Frontera
92-98
91146914
Radiator
Frontera
2.3TD
92-98
91147085
Frontera
92-98
91147090
Rear door glass, opening, RH (91142088)
Frontera
92-98
91147110
Exhaust gasket
Frontera
2.0,2.2,2.4,2.5TD,2.8TD
92-98
91147149
Check link door Rear
Frontera
RV633222-
92-98
91147854
Hose heater LHD
Frontera
x22xe
92-98
91147918
Hose distributor to pump
Frontera
2.0, 2.2
92-98
91147919
Hose, distributor to thermostat
Frontera
x22xe
92-98
91148068
Radiator hose, outlet
Frontera
X2.2XE
92-98
91148168
Hose,heater LHD
Frontera
x20, x22
92-98
91148170
Heater hose
Frontera
X20SE,X22XE,25TD
92-98
91148194
Clutch plate Ident AY
Frontera
92-
91148293
Fuel pipe, tank to filter
Frontera
2.5/2.8TD
92-98
91148750
Heater pipe assembly
Frontera
2.3TD
92-98
91148830
ECU, anti theft
Frontera
92-98
91148860
Mirror glass, Rh, convex
Frontera
manually operated
92-98
91148920
Switch assembly, anti theft
Frontera
2 door
92-98
91149167
Radiator inlet hose
Frontera
C20NE
92-98
91149170
Hose, engine to radiator outlet
Frontera
2.3TD
92-98
91149174
Radiator ooutlet hose
Frontera
C24NE
92-98
91149280
Seat frame R/H
Frontera
4 door
92-98
91149314
Towing socket kit
Frontera
92-98
91149345
Bushes, shock absorber
Frontera
set of 4
92-98
91149349
Rear shockabsorber bush
Frontera
92-98
91149589
Brake shoes, Isuzu
Frontera
92-98
91149642
Hand brake shoes
Frontera
92-98
91149685
Spark plug, WR8DC4, BPR5ES
Frontera
C2.0NE
92-98
91149901
Battery positive cable
Frontera
2.8 D
92-98
91150071
Shear bolt, ign switch
Frontera
92-
91150217
Heater hose
Frontera
2.3TD
92-98
91150256
Windcreen wiper arm & blade
Frontera
SV703369-
92-98
91150258
Wiper arm, rear
Frontera
2 door
92-98
91150827
Door link, tail gate
Frontera
4 dr
92-98
91150834
Door handle, outer front
Frontera
R/H
92-98
91150847
Door handle, tail gate
Frontera
4 dr
92-98
91151031
Bonnet
Frontera
92-98
91151117
Harness alternator
Frontera
92-98
91151144
Immobilizer status indicator
Frontera
92-98
91151398
Seat belt inertia wheel
Frontera
92-98
91151457
Rear seat belt, centre
Frontera
4 door WL4
92-98
91151471
Mirror assembly, L/H manual adj
Frontera
Convex, SV720103 on
92-98
91151474
Mirror cover, LH, Ebony
Frontera
92-98
91151475
Mirror cover,RH
Frontera
92-98
91151476
Mirror cover
Frontera
L/H
92-98
91151477
Mirror cover,RH, primed
Frontera
92-98
91151487
Mirror assembly L/H manual adj
Frontera
Convex, to SV720102
92-98
91151490
Mirror cover, LH
Frontera
92-98
91151512
Air cleaner top
Frontera
2.8 D
92-98
91151649
Crank bearing, centre
Frontera
std, 2.5TD
92-98
91151654
Crank bearing, front
Frontera
std, 2.5TD
92-98
91151678
Bearing, idler
Frontera
2.5TD
92-98
91151683
Crank bearing, rear
Frontera
std, 2.5TD
92-98
91151732
Alternator upper mounting bracket
Frontera
2.5TD
92-98
91151760
Hose,fuel return,injector
Frontera
25TD
92-98
91151788
Head bolt
Frontera
2.5TD
92-98
91151789
Head bolt
Frontera
2.5TD
92-98
91151790
Head bolt
Frontera
2.5TD
92-98
91151821
Gasket, turbo to front pipe
Frontera
2.5TD
92-98
91151973
Speaker tweeter, front door
Frontera
92-98
91152146
Rubber moulding, roof drip, front door RH
Frontera
4 door
92-98
91152248
Hose, rear axle breather
Frontera
92-98
91152372
Wheel centres
Frontera
92-98
91152605
Nudge bar, black
Frontera
92-98
91152689
Handbrake cable, LH
Frontera
4 Door
92-98
91152761
Heat sheild
Frontera
C20NE
92-98
91153038
Exhaust, front pipe with cat
Frontera
X2.2XE,SV728281-
91153271
Radiator
Frontera
Aircon
92-98
91153331
Aircon pipe, to evaporator
Frontera
X2.0SE, X2.2XE,2.5TD
92-98
91153353
Aircon pipe
Frontera
X20SE,X22XE
92-98
91153406
Radiator inlet hose,RH
Frontera
25TD
92-98
91153443
Oil cooler pipe
Frontera
25TD
92-98
91153561
Bumper skin,front
Frontera
92-98
91153798
Lens & reflector
Frontera
92-98
91153827
Rocker arm inlet valve
Frontera
2.5TD
92-98
91153864
Gasket, water ret housing
Frontera
2.5TD
92-98
91153881
Stud, manifold to turbo
Frontera
2.5TD
92-98
91153914
Injector
Frontera
2.5TD
92-98
91153918
Sensor
Frontera
25TD
92-98
91153919
Glow plug
Frontera
25TD
92-98
91153953
PCB
Frontera
92-98
91154209
Stud/ball, tail gate strut
Frontera
4 dr
92-98
91154269
Tailgate stay
Frontera
4 door
92-98
91154280
Sun visor
Frontera
92-98
91154367
spare wheel carrier
Frontera
4 door
92-98
91154376
Front bumper centre
Frontera
no headlamp wash
92-98
91154377
Front bumper
Frontera
92-98
91154422
Front door, RH
Frontera
92-98
91154536
Non return valve, washer
Frontera
92-98
91154538
Washer non return valve
Frontera
92-98
91155296
Engine ECU
Frontera
2.5TD
92-98
91155810
Windscreen washer jet
Frontera
92-98
91155810
Frontera
98-
91155895
RH door trim
Frontera
92-98
91156470
power steering hose
Frontera
LHD
92-98
91156475
Hose, steering gear to pump
Frontera
X20SE,X22XE,LHD
92-98
91156546
Oil cooler return hose
Frontera
2.2D
99-
91156760
Seat release cable
Frontera
2 door
92-98
91156833
Front seat guide rail link
Frontera
2 dr
99-
91157033
Seat belt buckle & pretentioner LH
Frontera
99-
91157152
Mirror glass,convex,RH,manual
Frontera
99-
91157154
Mirror glass, RH,black
Frontera
heated
99-
91157752
Spare wheel cover strap
Frontera
99-
91158322
Mirror assembly,RH, breeze blue
Frontera
99-
91158370
Loud speaker
Frontera
92-98
91158491
Gasket, water pump
Frontera
2.5TD
92-98
91159327
Horn, high note
Frontera
99-
91159329
Indicator lamp LH
Frontera
92-
91161308
Harness engine (D1C)
Frontera
2.2 DTH
99-04
91161390
Radiator grille housing
Frontera
2V500001-
99-
91161394
Radiator grille,primer
Frontera
2v500001-
99-
91161395
Radiator grille, chrome ""V"
Frontera
99-
92061758
Brkt timing gear
Frontera
x22xe
92-99
92062024
Bearing set, con rod standard
Frontera
X22XE
92-98
92062553
Oil pick up pipe
Frontera
2.0-2.2SE/XE
92-98
92062599
Gasket, EGR valve
Frontera
2.2XE
92-98
92062689
Hose
Frontera
X22SE,Y22SE
99-
92062795
Oil pan Baffle plate
Frontera
2.0-2.2SE/XE
92-98
92063308
Spark plug
Frontera
X22SE
99-
92063944
Cam belt
Frontera
X2.2XE from VV600001
93156958
Oil Filter VOF 136
Frontera
2.4P
92-98
93171176
Map Sensor
Frontera
99-
93173864
Headlamp, RH
Frontera
2V500001-
99-
93181716
Belt, Alternator, 21.36 x 1725mm
Frontera
22SE
99-
93192726
Head gasket 1.52mm
Frontera
2.5TD
92-98
94002500
O ring rear output shaft
Frontera
99-
94020255
O' ring, speedo drive
Frontera
C20NE,X20SE,C24NE,23TD,X22XE,25TD,28TD
92-98
94020255
O'ring speedo guide
Frontera
99-
94031590
Trim clip, side mouldings
Frontera
92-98
94061601
Clutch slave cylinder, repair kit
Frontera
C20NE,C24NE,23TD
92-98
94112911
Relay, rear foglamp & heated rear window
Frontera
92-98
94123004
Locking mechanism clip, green
Frontera
4 door
92-98
94125859
Copper ring injector to head
Frontera
2.8 D
92-98
94152283
Rocker screw
Frontera
2.8TD
92-98
94167750
Nipple oil
Frontera
2.8 D
92-98
94171541
Gear box selector fork pins
Frontera
All models
92-98-
94172376
Brake disc,front
Frontera
92-98
94178081
Gasket water pump to block
Frontera
2.8 D
92-98
94198570
Plate,fixing,luggage floor carpet
Frontera
2 dr
92-98
94218497
Relay, various
Frontera
92-98
94222524
Pedal rubber
Frontera
92-
94227138
Front suspension bush
Frontera
92-98
94234319
Bush,shackle
Frontera
C20NE,C24NE,23TD
92-98
94242412
Delay valve
Frontera
28TD
92-98
94316900
Torsion bar, R/H
Frontera
92-98
94318661
Lock assembly, tailgate
Frontera
4 dr
92-98
94326439
Rubber o ring injector to head
Frontera
2.8 D
92-98
94334338
Gasket EGR valve to inlet man
Frontera
2.8 D
92-98
94337444
Starter solenoid
Frontera
92-98
94340317
Rear gearbox oil seal
Frontera
2.0P
92-98
94340670
Gasket EGR pipe
Frontera
2.8 D
92-98
94342907
Under wing splash panel
Frontera
92-98
94360802
Arm height control
Frontera
92-98
94365674
Gasket stat cover
Frontera
2.8 D
92-98
94368587
Thermostat housing
Frontera
2.8 D
92-98
94368591
Switch thermo
Frontera
2.8TD
92-98
94379499
Clutch release bearing
Frontera
28TD
92-98
94380833
Grommet
Frontera
92-98
94381452
Indicator switch assy LHD, 97068771
Frontera
-TV899999
92-98
94381454
Indicator switch assy RHD, 97068773
Frontera
-TV899999
92-98
94382247
Hose bypass
Frontera
2.8TD
92-98
94388235
Bonnet hinge LH
Frontera
92-98
94422071
Nut, mainshaft gears
Frontera
C24NE,X22XE,23/25/28TD
92-98
94422600
Cock assy water
Frontera
2.8TD
92-98
94427298
Gasket, clutch M/cylinder
Frontera
92-
94433604
Gasket turbo to ex/adaptor
Frontera
2.8 D
92-98
94433605
Gasket turbo to manifold
Frontera
2.8 D
92-98
94433744
Gasket cover to cylinder head
Frontera
2.8TD
92-98
94434926
V belt with AC
Frontera
2.8D
92-98
94434926
V belt with AC
Frontera
2.8 D
92-98
94441538
Bonnet stay clip
Frontera
92-98
94450010
Central door locking motor
Frontera
92-98
94450648
Front fog light switch
Frontera
92-98
94450651
Heated rear window switch
Frontera
92-98
94455667
head bolt
Frontera
28TD
92-98
94457511
Switch thermo
Frontera
2.8 D
92-98
94473946
Front gearbox cover gasket
Frontera
92-98
94473955
Tube air intake
Frontera
2.8TD
92-98
96014187
Clutch plate
Frontera
auto
99-
97004212
Lock set
Frontera
2 Door -TV899999
92-98
97004218
Head light switch assy LHD
Frontera
92-98
97020923
Frontera
20NE,SE,22XE,24NE,23TD,25TD
92-98
97020923
Frontera
22SE,22DTH
99-
97020953
Steering joint
Frontera
R/H thread
92-98
97020954
Track rod end, LH
Frontera
92-98
97034035
Brake disc
Frontera
Non ABS
92-98
97034035
Brake disc
Frontera
Non ABS
99-
97038956
Switch thermo
Frontera
2.8 D
92-98
97039269
Rear brake pads
Frontera
92-98
97043021
EGR valve
Frontera
2.8 D
92-98
97061270
Throttle valve assy
Frontera
2.8TD
92-98
97062913
Belt alt/water pump
Frontera
2.8 D
92-98
97065983
Gasket oil filter & cooler to block
Frontera
2.8 D
92-98
97086961
Gasket inlet pipe throttle valve
Frontera
2.8 D
92-98
97089891
Thermostat
Frontera
2.8TD
92-98
97102031
Gasket, front pipe to manifold
Frontera
3.2P
99-
97103271
injection pump without immo
Frontera
2.8 D
92-98
97103274
Injector assy
Frontera
2.8 D
92-98
97105012
Water pump
Frontera
2.8 D
92-98
97106505
Hose assy
Frontera
2.8 D
92-98
97108787
Harness engine without immo
Frontera
2.8 D
92-98
97109216
Gasket ex/manifould to head
Frontera
2.8 D
92-98
97110867
Power steering pump assy (with pulley & brkt)
Frontera
2.8 D
92-98
97113069
Gasket sump lower
Frontera
2.8 D
92-98
97114300
Front brake pads
Frontera
Early type with drum rear
92-98
97115455
Housing air inlet
Frontera
2.8TD
92-98
97117211
EGR transfer pipe assy
Frontera
2.8 D
92-98
97117260
EGR valve adaptor to transfer pipe
Frontera
2.8 D
92-98
97117515
injection pump with immo
Frontera
2.8 D
92-98
97118615
Indicator stalk
Frontera
92-98
97118753
Engine oil filler cap
Frontera
2.8 D
92-98
97118768
Rocker cover gasket
Frontera
2.8TD
92-98
97119174
Harness engine with immo
Frontera
2.8 D
92-98
97120442
Exhaust mounting
Frontera
2.2SE,3.2,2.2DTH
99-
97120931
Rear oil pan seal
Frontera
28TD
92-98
97122568
Sump bottom cover
Frontera
2.8 D
92-98
97123117
Door lock, RH
Frontera
4 dr
92-98
97124151
Tail gate seal, upper
Frontera
4 dr
99-
97124823
Weatherstrip, rear door, LH
Frontera
4 door
98-
97124927
steering joint assy universal
Frontera
99-
97125195
Bonnet hinge LH
Frontera
99-
97125249
Front door lower moulding LH
Frontera
99-
97125441
Relay
Frontera
99-
97125492
Hinge, tail gate
Frontera
99-
97125801
Bumper bracket, rear
Frontera
R/H
99-
97125801
Rear bumper bracket RH
Frontera
99-
97125802
Rear bumper bracket LH
Frontera
99-
97125809
Inner bumper bracket rear R/H
Frontera
all models
99-
97125810
Inner bumper bracket rear L/H
Frontera
all models
99-
97125969
Spark plugs RC10PYP4
Frontera
2.2,3.2
99-
97127454
Ing/pump immo switch brake head bolts
Frontera
2.8 D
92-98
97129413
Fuel injection return hose
Frontera
28TD
92-98
97129429
Front cover gasket
Frontera
28TD
92-98
97129593
Power steering pump
Frontera
2.8 D
92-98
97130561
Poly v belt
Frontera
3.2P
99-
97131099
Moulding,roof,front,LH
Frontera
4 dr
99-
97135540
Bumper bracket, side panel LH
Frontera
99-
97135932
Steering arm
Frontera
97136307
Bolt m10x95 shim to gear box
Frontera
99-
97136904
Pipe to power steering pump
Frontera
2.2SE
99-
97137018
Hose throttle valve to inlet/man
Frontera
2.8TD
92-98
97137021
Brake servo
Frontera
2.2-3.2 P
99-
97138820
Frontera
99-
97138981
CV boot kit, front
Frontera
X22XE, 25TD,28TD
92-98
97139416
Frontera
all models
99-
97139527
Bracket,bumper to rear end panel
Frontera
99-
97143727
N/S wing
Frontera
99-
97143886
Clutch master cylinder to damper hose
Frontera
97143951
Rear lamp
Frontera
not listed
97144062
Outer/Inner rear qtr RH
Frontera
2 dr
99-
97144143
Petrol cap
Frontera
99-
97144146
Wiper motor,back door
Frontera
2 dr
99-
97144202
Condenser, air con
Frontera
99-
97144428
Weather strip, door inner, RH
Frontera
99-
97144429
Door aperture seal, front, LH
Frontera
99-
97144515
Front end stay
Frontera
99-
97144550
Front Bumper black for headlamp wash
Frontera
99-
97144551
Front Bumper black not headlamp wash
Frontera
99-
97147566
Brake back plate,RH
Frontera
92-98
97147976
Tail gate seal, RH
Frontera
4 dr
99-
97148450
Bracket,rear bumper side, LH
Frontera
99-
97148450
Frontera
99-
97148451
Bracket, rear bumper side, LH
Frontera
All
99-
97148724
Disc clutch service No9195998
Frontera
X22 DTH
99-
97148749
CV boot kit
Frontera
99-
97148777
Console bracket
Frontera
rear
99-
97149803
Bracket,front bumper support, LH
Frontera
99-
97149836
Engine Mounting,front, RH, rubber
Frontera
X22DTH,Y22DTH
99-
97154865
Lower dash moulding
Frontera
92-98
97165854
"2.2-16V" badge
Frontera
X22SE,Y22SE
99-
97166290
gasket, front pipe to manifold
Frontera
X22SE,Y22SE
99-
97166558
Door mirror assy RH
Frontera
99-
97169883
Windscreen wiper arm, RH
Frontera
99-
97174586
Electric window switch,LH
Frontera
99-
97176000
Sump shield
Frontera
99-
97176992
Aerial harness
Frontera
car phone
99-
97178853
Rear wiper blade
Frontera
99-
97178966
Rear qtr glass RH fixed
Frontera
2 dr hard top
99-
97179442
Shock absorber,front
Frontera
4 dr
99-
97179459
Extension, handle jack & wheel wrench
Frontera
99-
97179506
Shim, 3.2mm arm to frame
Frontera
99-
97179507
Shim,1.6mm arm to frame
Frontera
99-
97180749
Frontera
X22DTH,Y22DTH
99-
97180751
"RS" badge front door
Frontera
2dr
99-
97182314
Sponge pad, front skid plate
Frontera
99-
97182386
ABS sensor LHF
Frontera
99-
97190774
Locking wheel nut, spare wheel
Frontera
99-
97195873
Rear cup holders
Frontera
4 door
99-
97201163
header tank cap
Frontera
X22DTH,Y22DTH
99-
97201441
Brake pad kit, front
Frontera
with MFD
99-
97206092
Switch, heated back window
Frontera
X22SE,X22DTH,Y22DTH
99-
97206384
Outer rear door handle, RH
Frontera
4door
99-
97207653
Harness battery neg and alternator
Frontera
X22 Y22 DTH
99-04
97209350
Front panel assembly
Frontera
all engines
99-
97211846
Moulding,front wing lower,LH,black
Frontera
99-
97211850
Body moulding,rear door, lower,LH,black
Frontera
4 dr
99-
97213871
Wheel stud
Frontera
92-
97214628
Exhaust back box
Frontera
3.2P LWB
99-
97219632
Moulding,front door,lower,LH
Frontera
99-
97222167
Wheel centre, 15x 6.5J
Frontera
99-
97224545
Body moulding,rear qtr,RH,black
Frontera
2dr
99-
97229212
Wheel nut
Frontera
97292188
Front door lock & motor
Frontera
for central locking
99-
97315932
Steering lever
Frontera
92-98
97326535
Panhard Rod
Frontera
X20SE,22XE,25,28TD
92-98
97365654
Clutch arm
Frontera
28TD
92-98
97714044
V belt non AC
Frontera
2.8 D
92-98
97723532
Seal, wiper pivot
Frontera
99-
97723532
Windscreen wiper motor seal
Frontera
99-
Bosch No 0280155712
Injector (Blue)
Frontera
Bosch No 0280155712
Injector (Blue)
Frontera
R1030017
Alternator Delco
Frontera
C20NE
92-98
R1740064
Brake caliper, rear disc, LH (97144479)
Frontera
92-98
Front door hinge
Frontera
rear seat back LH
Frontera
seat covers
Frontera
Injector clamp
Frontera
2.8 D
92-98
Immo sensor/led (Tec-Tus)
Frontera
92-98
Steering lock / upper bearing assy
Frontera
92-98
Oil pipe turbo to sump
Frontera
2.8 D
92-98
Dip stick
Frontera
2.8 D
92-98
Injector
Frontera
2.2 DTH
Injector
Frontera
2.2 DTH
Part Number
Description
Model
Type
crash_ndie
Vehicle Name: the hulk
Re: part numbers by Drift on Thu Dec 20, 2012 6:31 pm
Hi, Vauxhall green parts is a site we have been recommending for years :wink:
viewtopic.php?f=12&t=36854
Its best visit the site or phone them as the stock is changing all the time so a cut and paste wouldnt be effective :thumbup:
Re: part numbers by badsykes on Wed Feb 06, 2013 8:35 pm
I have another sugestion ...
www.partsbase.org
The strange thing it should be for more manufacturers but only Opel ones are there...Anyway for Frontera A and B the database look nice..I found the codes that are pretty rare ...I wish i could save the frontera database to my HDD so i can access it offline..
badsykes
Vehicle Name: KIY
Modifications: STOCK ... except MAF unplugged from time to time for (in)sanity reasons..
Return to Frontera History/Data
