ABS warning light
ABS warning light by nwfo837 on Fri Aug 02, 2019 3:06 pm
I replaced the rubber boot on the front drive shaft and since then I the ABS warning light is on. It has failed its' MOT on said warning light.
My local garage has tried 3 different diagnostics but they don't detect the fault?
Any suggestions? Can't get it thru the MOT until its fixed
nwfo837
Re: ABS warning light by Munfred on Fri Aug 02, 2019 9:57 pm
Might have knocked the sensor or wiring when you changed the boot.
They get quite brittle from age.
Check the condition
Munfred
Re: ABS warning light by nwfo837 on Sat Aug 03, 2019 6:11 am
What about which diagnostics fits my vehicle?
Any ideas?
nwfo837
Re: ABS warning light by nwfo837 on Sat Aug 03, 2019 6:12 am
Its an 03 3.2 V6
nwfo837
Re: ABS warning light by Munfred on Mon Aug 05, 2019 8:27 am
Tech2?
Munfred
Re: ABS warning light by stretch on Mon Aug 05, 2019 5:39 pm
I couldn't get opcom to talk to my 03 3.2 it needed tech2
