Frontera Technical Support • View topic - Hiccup
Hiccup
Hiccup by SnortonR on Fri Oct 12, 2018 12:01 pm
Hi, I've got a persistent problem but it's not really causing any worry; just a nuisance.
The car hiccups. It's as though fuel stops for a split second. I've read that it's the MAF sensor. There's cheap replacements but I thought the real thing from a breaker would be better. I've changed it but the same problem's there although less noticeable. I suppose being used and of unknown mileage it could have the same problem but may it be something else?
While ebaying replacements I came across maf cleaning sprays. I've got an electrical contact cleaner which I suppose does the same job and I'm trying that now.
If that doesn't fix it is it worth me getting a replacement sensor only rather than the whole caboodle - they're about 39.00 on the bay.
Is it a precurser for a future major problem?
Thanks in advance for any help.
SnortonR
Registration Year: 2004/04
Re: Hiccup by robbie on Fri Oct 12, 2018 8:21 pm
When does it hiccup.
Is it when you go to accelerate?
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: Hiccup by robbie on Fri Oct 12, 2018 8:45 pm
Just read your other post. Take the throttle position sensor off and chech the plastic link.
robbie
2.0 1997 the gold1.
2.0 1997 green1.
Re: Hiccup by SnortonR on Mon Oct 15, 2018 1:32 pm
Thanks Robbie. I need some help locating that. Is it at the pedal or throttle?
SnortonR
Re: Hiccup by robbie on Mon Oct 15, 2018 2:00 pm
Side of intake manifold 3 wires I think and 2 bolts
robbie
2.0 1997 the gold1.
2.0 1997 green1.
Re: Hiccup by vauxsqueeks on Mon Oct 15, 2018 4:16 pm
If you haven't put any injector cleaner through it, put a bottle in with 30 litres of fuel or so and run that through completely. if it starts coughing/spluttering then you have found your problem.
try to get through the lot though as you will need to replace your fuel filter after if the system is dirty. I got about 20 miles in mine, before it died at the side of the road and had to do a fuel filter change roadside to get going again.. was fine after.
Also clogged egr can cause coughing at speed.
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Re: Hiccup by SnortonR on Mon Oct 15, 2018 7:41 pm
I run it with redex every second tank if Tesco have it for 2.00. Is injector cleaner different?
SnortonR
Re: Hiccup by vauxsqueeks on Tue Oct 16, 2018 5:45 pm
Now Gone
vauxsqueeks
Re: Hiccup by SnortonR on Tue Oct 30, 2018 8:36 pm
I tried the electrical contact cleaner on the replacement and it was worse. I've put the original back and living with that until I've time to work through the suggestions:
vacuum pipe at throttle body; throttle position; crank position; clean injectors.
Discovered it will run without maf sensor connected. I'll try that too.
SnortonR
Re: Hiccup by SnortonR on Wed Oct 31, 2018 11:56 am
Silly Question?
If the car runs ok with maf sensor disconnected; what's the maf sensor for?
SnortonR
Re: Hiccup by vauxsqueeks on Fri Nov 02, 2018 2:10 am
Now Gone
vauxsqueeks
