Frontera B 2003 immobiliser problem!!
Frontera B 2003 immobiliser problem!! by Taff121 on Sun Jun 04, 2017 9:04 am
Hi , hope someone can help!! Just bought a 2003 frontera B and a couple of times it's cut out or won't start, re lock the car and try again, starts. !! And one time alarm kicked in and couldn't turn off !! Any help would be grateful, thanks paul
Taff121
Re: Frontera B 2003 immobiliser problem!! by stretch on Sun Jun 04, 2017 9:34 am
When it won't start is eml flashing?
Re: Frontera B 2003 immobiliser problem!! by Taff121 on Mon Jun 05, 2017 11:47 am
Eml? Not sure what that is sorry
Taff121
Re: Frontera B 2003 immobiliser problem!! by stretch on Mon Jun 05, 2017 5:13 pm
Engine management light
Re: Frontera B 2003 immobiliser problem!! by Taff121 on Mon Jun 05, 2017 7:45 pm
Doh, no wasn't on , it's cut out twice and would start again today, locked car tried again no luck.
I've been told now it's not immobiliser but fuel running back to tank? Is this possible? I'm ready to throw towel in !! But it's such a nice car.
Taff121
Re: Frontera B 2003 immobiliser problem!! by stretch on Mon Jun 05, 2017 9:58 pm
Normally eml flashes with immobiliser fault does it fail to start if you park with bonnet facing up hill? Mine had non starting/intermittent issue and was fuel draining back to tank replaces all pipes problem solved. Get it fixed as cranking with no fuel in the pump will knacker it and will cost about 1k
Re: Frontera B 2003 immobiliser problem!! by Taff121 on Tue Jun 06, 2017 5:03 am
Thank you, did you replace all pipes? From tank straight through? Or just on engine back to pump ? Ta
Taff121
Re: Frontera B 2003 immobiliser problem!! by stretch on Tue Jun 06, 2017 7:40 am
The leak off pipes can also cause similar issues and are cheap/easy to replace so start with these first. The pump is part of the engine in the bay and you would need to replace feed and return lines to the tank.
Re: Frontera B 2003 immobiliser problem!! by Taff121 on Wed Jun 07, 2017 10:50 am
Hi thank you for all your help, found return pipes on injectors split, changed pipes all seems ok running well at moment.
Fingers crossed, thanks for help, spot on
Taff121
Re: Frontera B 2003 immobiliser problem!! by stretch on Wed Jun 07, 2017 12:06 pm
Thats great keep us updated.
sometimes you need to wait a few seconds till most of the dash lights go out
If you turn to engage the car quickly it can sometimes overtake the immobiliser signal, I normally wait for about 5 secs before full ignition
Pete
Pete Stewart
