1998 2.2i won't run
1998 2.2i won't run by N44hnd on Fri May 26, 2017 10:57 pm
I have just changed the engine in my frontera, I can get it to fire up but it won't run just keeps cutting out it did run for about 10min's i turned it off and I have the problem of not running. Every time it fires up it just cuts out and the engine management light is flashing. Anybody have any idea what it could be thanks
N44hnd
Model: 2.2i Transglobe 5dr
Re: 1998 2.2i won't run by stretch on Sat May 27, 2017 8:06 am
Immobiliser fault? Fuel leak?
Re: 1998 2.2i won't run by vauxsqueeks on Sat May 27, 2017 11:25 am
Immobiliser.
As the MIL is flashing, this is now immobilising the engine.
Check your key transponder, pickup loop and connections to the immobiliser box under the drivers side dash.
Usually, this wouldn't run for more than a few seconds so I suggest that you may of had more than one issue if it ran for 10 minutes.. Fuel as Stretch said, maybe crank sensor ( intermittent ) As there is no spark when this fails.
Check compression, fuel supply and spark, engine earths, engine loom.. Work back from there.
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Re: 1998 2.2i won't run by N44hnd on Sat May 27, 2017 4:22 pm
I changed the crank sensor still no joy all of the wires are OK no breaks or any left not connected. Could it be the injectors as I didn't use the original ones could they be coded or are they plug and play thanks for previous reply
N44hnd
Re: 1998 2.2i won't run by stretch on Sat May 27, 2017 4:37 pm
Did you use bosch crank sensor? What injectors did you use?. I had similar issue and was leak off pipes.
Re: 1998 2.2i won't run by dave1966 on Sat May 27, 2017 5:04 pm
Hello bud.
It would be a big help to everyone, if you could give abit more information on what Frontera you have rather than 1998 2.2i. This way it narrows it down for other members with advice and ideas for you.
Welcome to the wonderful world of fog.
R.I.P Sable!(2005 to 2013)
dave1966
Re: 1998 2.2i won't run by N44hnd on Sat May 27, 2017 5:19 pm
Yeah was the original crank sensor i tried back in there that came of it just checked for fuel coming up I have got plenty coming through the lines and have spark, the injectors were of the engine I bought thinking about using the original injectors to try it it's the x22xe engine last of the a series shape thanks
N44hnd
