3.1 trooper injector pump removal
3.1 trooper injector pump removal by lee771 on Sun Apr 09, 2017 4:26 pm
Hi guys I've been fighting with my 3.1 today trying to get the injector pump off
All blots are undone even the ones that require 3 elbows and a whole lot of luck to get to, I just can't get it to separate from the timing pully what am I doing wrong?
Thanks
Lee
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: 3.1 trooper injector pump removal by snapper on Sun Apr 09, 2017 5:05 pm
Have to ask, why?
As to the timing pulley I think that I would remove that first while the pump was in position using a puller... And being ever so carful not the muller the thing!
Consider the fact that the pulley has no doubt been there since new and will be tight to remove, use of some easing fluid may be required....
Sometimes it is useful to just take up pressure with a puller, apply easing fluid and leave it be for a bit.
Re: 3.1 trooper injector pump removal by lee771 on Sun Apr 09, 2017 5:14 pm
Am breaking the trooper and using the money to mod my frontera, and have had a request for the pump.
Does the pulley have to be in a certain place when using the puller? Never used one before any advice would be good
And thanks for the reply
lee771
33 12.5 15s
Re: 3.1 trooper injector pump removal by snapper on Sun Apr 09, 2017 7:06 pm
Image above shows the 2.8 engine (not got time to go and rip the 3.1 engine in truck to bits for a few pics atm) which is close enough.
You can lock the pulley up using the same method for doing a belt change. Then remove the nut holding the pulley to the shaft and un-lock the pulley once that nut is off. The puller is going to line up on the shaft end with the three (use a three legged one rather than a two legged one when ever possible) legs hooking over the outer edge of the pulley.
Re: 3.1 trooper injector pump removal by lee771 on Sun Apr 09, 2017 8:47 pm
Awesome thank you big help gone see If I can pick up a 3 legged puller in the morning
Again thanks for the reply
lee771
33 12.5 15s
Re: 3.1 trooper injector pump removal by lee771 on Mon Apr 10, 2017 6:16 pm
Just to say thanks for the advice got a puller for £6 and it came off in less than 2 minuets things are so much easier with the right tools and the added confidence you get when some one that knows there stuff gives you the detals
Many thanks
Lee
lee771
33 12.5 15s
