Bleeding fuel system
Bleeding fuel system by Dooley on Sun Mar 12, 2017 3:48 pm
So I'm bleeding my fronts anyone else had same trouble,
Dooley
Model: 2.5 TDS Sport 3dr
Vehicle Name: Beast
Re: Bleeding fuel system by Retro Pedro on Mon Mar 13, 2017 11:07 am
What trouble you having mate?
Usually they hand prime on the fuel filter under the bonnet. If it's not having it, try feeding from a can post the filter. If it fires up then chances are you might be getting air in the fuel lines pre the filter.
Re: Bleeding fuel system by Dooley on Mon Mar 13, 2017 7:48 pm
Well I have a new pump and filter fill filter with fuel prime with pump try starting she runs then stalls filter is low or empty.
I'm guessing leaking hose in fuel line from tank or in fuel tank?
Dooley
Vehicle Name: Beast
Re: Bleeding fuel system by robbie on Tue Mar 14, 2017 9:46 am
Thats the same as my 2.5tds fuel lines have gone pores
robbie
Vehicle Name: The white 1
Modifications: 2.5 the white1
2.0 1997 the gold1.
2.0 1997 green1.
Re: Bleeding fuel system by Dooley on Tue Mar 14, 2017 11:32 am
Thanks for help
Dooley
Vehicle Name: Beast
Re: Bleeding fuel system by Dooley on Tue Mar 14, 2017 7:41 pm
It is the fuel pipe blew the compressor down from filter to tank and saw spray of fuel near rear wheel arch.
Dooley
Vehicle Name: Beast
Re: Bleeding fuel system by robbie on Tue Mar 14, 2017 9:25 pm
Glad you found the problem. If I were you I would replace the return as well
robbie
2.0 1997 the gold1.
2.0 1997 green1.
Re: Bleeding fuel system by jmc on Sat Mar 18, 2017 7:40 pm
Well done for finding the problem and thanks for posting.
jmc
