Not starting
Not starting by Dooley on Sat Mar 11, 2017 1:57 pm
I need help with my 2.5 tdi sport 97plate, she won't start, new batterie, starters fine, alternater fine, new glow plugs, leads in good order, egr cleaned with new gaskets, new/second hand pipes, new manual fuel pump that primes fine.
So I try to start it turns over for at least 5 to 10 seconds then starts but stalls almost immediately, I keep getting air in the manual pump breather bolt, I bleed then more appears, I've filled fuel filter with fuel, prime system so no more air bubbles and start again, same thing long turn over starts then stalls.
Is there a pump in the fuel tank could this be the problem?
Dooley
Model: 2.5 TDS Sport 3dr
Vehicle Name: Beast
Re: Not starting by lee771 on Sat Mar 11, 2017 2:35 pm
I had a similar problem years ago on a pajaro 2.5, it was poures fuel lines letting air in. Replaced the lot from the tank forward with rubber line and it ran perfect I would suggest the same for yours
lee771
Modifications: +2" suspension
33 12.5 15s
-32 offset steel rims
Landrover arch extension
Re: Not starting by lee771 on Sat Mar 11, 2017 2:45 pm
Also the fuel pick up line in the tank can perish and if the fuel level is below the point it's perished all you will get is air being sucked through.
Is there much fuel in her? May be worth getting some in with Jerry can
lee771
33 12.5 15s
Re: Not starting by Dooley on Sat Mar 11, 2017 3:07 pm
Dooley
Vehicle Name: Beast
