Cooling Radiator Fan
Cooling Radiator Fan by Jonah on Thu Aug 04, 2016 11:01 am
Hi Everyone
I need your help, I have a 2003 DTI and the radiator cooling fan no longer comes on and has overheated a couple of times.
I checked the fuses and they are all ok.
I can't seem to find the switch sensor thingy that tells thr fan to start?
It was working fine till the missus drove it!!
Regards
Paul
Jonah
Modifications: Washed it
Re: Cooling Radiator Fan by fogman on Thu Aug 04, 2016 8:12 pm
you should have 3 ( iirc) relays above the battery on offside wing, im not sure which does what but they or at least 1 operates the fan so check those.
