Frontera Technical Support • View topic - Hub bearing
Hub bearing
Hub bearing by mickh on Thu Jun 16, 2016 5:59 pm
Does anybody know where I can get a front hub bearing from. This is the bearing that supports the drive shaft to the hub not the wheel bearings. Vauxhall can get one from Germany which will take 5 working days but I am impatient and want one now.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: Hub bearing by RatCav on Thu Jun 16, 2016 7:11 pm
Do you mean the needle bearing the CV joint runs on inside the steering knuckle stub?
If so Milners stock genuine Isuzu, or Isuzu can get them next day.
Re: Hub bearing by RatCav on Thu Jun 16, 2016 7:28 pm
Part "3"
Part number 94407708 (Isuzu Part Number 8944077080)
Worth getting the thrust washer as well. They are only a couple of quid.
Worth noting Isuzu are only £1 more expensive .. and don't charge £5,000,000 delivery ;)
Re: Hub bearing by stretch on Thu Jun 16, 2016 7:51 pm
Beat me to it lol, I think milner do them but not sure on the quality.
Re: Hub bearing by RatCav on Thu Jun 16, 2016 8:05 pm
Re: Hub bearing by mickh on Thu Jun 16, 2016 8:12 pm
Thanks men you nailed it. Neal where do I get the Isuzu ones to save on the postage if its too high.
mickh
Front winch.
CB radio.
Re: Hub bearing by stretch on Thu Jun 16, 2016 8:49 pm
Re: Hub bearing by snapper on Thu Jun 16, 2016 9:07 pm
Same job as me, using Milner's parts.
Re: Hub bearing by RatCav on Thu Jun 16, 2016 9:28 pm
Re: Hub bearing by mickh on Sat Jun 18, 2016 7:48 pm
So far so good. Ordered the parts from Milners thursday night and they duly turned up today via good old Yoda. They look the right parts so fingers crossed.
mickh
Front winch.
CB radio.
Re: Hub bearing by RatCav on Sat Jun 18, 2016 8:11 pm
Good luck getting the old ones out. The washer should be easy to pull out past the seal.
The needle bearing is different. I ended up making a drift tool to push it out from the other end (wheel side).
When you look inside the stub you will see the bearing sits in a larger diameter step. I took a chisel and ground the end flat. I then ground the side to have an angled notch. I plan on doing mine tomorrow so will take photos.
Re: Hub bearing by RatCav on Tue Jun 21, 2016 9:06 pm
This is what I use to drift the bearing out. You drop it in front the front and put the notched bit up against the back of the needle bearing and tap, move around 90 degrees. tap, move round 90 degrees etc etc etc.
Just done one and it came out a treat.
