Clutch pedal pivot bushes
Clutch pedal pivot bushes by Chapstick44 on Mon Jun 06, 2016 6:21 pm
Hi,
My clutch pedal has recently got very squeaky when depressed when changing gear.
The pedal has slight sideways (side to side) movement as well.
I was going to renew the pivot bushes and return spring.
Unfortunately my local Vauxhall dealer says the parts are obsolete.
Can anyone point me in a direction of any after market supplier's of these parts?
Any comments /suggestions appreciated. Thanks.
Chapstick44
Re: Clutch pedal pivot bushes by pot bellied pixie on Mon Jun 06, 2016 10:03 pm
I fashioned a bush from the remains of the inner race from a 2.5tds idler pulley . centre hole is close but the race remains are a bit too thick so have to be trimmed to fit.
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: Clutch pedal pivot bushes by fudge on Tue Jun 07, 2016 7:43 pm
If you know the mesurments i could make some out of nylon
Re: Clutch pedal pivot bushes by Chapstick44 on Wed Jun 08, 2016 3:11 pm
Thanks for the couple of replies above :D
Fudge - Thanks for the offer of making some nylon ones. I'll need to take my old ones off to get measurements etc. As and when I get the time to do this I'll let you know. In the meantime I'll have to put up with the squeak.
Chapstick44
