fuel injection pump
fuel injection pump by Pete Stewart on Sun Apr 17, 2016 3:25 pm
Hi All
I've been told (by an autospark) that my fuel injection pump has gone & that's why my engine management light is on. The car does not start from cold although I can start it when I spray 'Easy Start' into the air filter and after I drive it for a few miles it will start from warm ?
Would anyone know where I could obtain a recondition pump or if any cracked piped might cause be the problem
Are there any other easy checks that I could make before spending the sum to replace the pump ?
Frontera 2001 2.2 DTI (100,000 miles clocked)
thanks
Pete
Pete Stewart
Re: fuel injection pump by hipo1024 on Sun Apr 17, 2016 8:12 pm
Have the bleed off pipes from the injectors been replaced? Sounds more like you have a fuel drain back problem
Re: fuel injection pump by stretch on Sun Apr 17, 2016 9:38 pm
Normally these pumps work or they die completely, as hipo said try changing leak off pipes mine had this issue and changing em sorted it.
Re: fuel injection pump by Pete Stewart on Mon Apr 18, 2016 12:09 pm
Thanks guys & will try replacing the bleed off pipes (fingers crossed)
Don't fancy replacing the injector pump .....£££
Will keep you posted on how I get on
Peter
Pete Stewart
Re: fuel injection pump by stretch on Mon Apr 18, 2016 5:18 pm
Don't forget you MUST bleed the fuel system after doing so and BEFORE you attempt to start the car.
Re: fuel injection pump by Pete Stewart on Tue Apr 26, 2016 12:33 pm
Many Thanks Hipo & Stretch, replacing the leak pipes seemed to have worked :thumbup:
Once the pipes (which were corroded & pitted) were replaced it fired up 1st time yesterday
It didn't start quite as smoothly this morning but will take it from here
Not sure how much longer can keep the Fonty running as there is an unbelievable amount of rusting on the tank brackets & thereabouts
Thanks again for your correct suggestions
Pete :drink:
Pete Stewart
