Wont start in cold weather =(
Wont start in cold weather =( by Depressed on Fri Jan 08, 2016 1:51 pm
Hi im struggling to start my 2.2dti when the temperature drops below 8 degree's it will turn over and has lots of battery power and all the leak off pipes have been replaced for brand new ones and are clear enough for me to see theres fuel in the lines and all the injector seals have very recently been replaced and the egr valve and the maf sensor have also been replaced also the lower inlet manifold has been replaced i dont have this problem once the weather temperature is above 8 degree's i only seem to have it when its lower than 8 degree's im wondering if it could have anything to do with the outside temperature sensor ? all my fuel lines from the tank and upto the engine are new like i say it starts first turn of the key if the temperature is above 8 degree's but below 8 degree's then ive no chance ? i really am giving up hope on this vehicle now ive spent a fortune on it and i have to say its been the most unreliable 4x4 i have ever bought Please can anyone shed some light on what it could be
Many Thanks in advance for any replies or help given
Depressed
Re: Wont start in cold weather =( by gregster on Fri Jan 08, 2016 3:04 pm
Have you changed the glowplugs?
Re: Wont start in cold weather =( by Depressed on Fri Jan 08, 2016 3:47 pm
Hi Gregster yes ive changed the glow plugs for new ones and also i fitted a glowplug bypass to try and help it but to no avail ?
Depressed
Re: Wont start in cold weather =( by martinkettering on Fri Jan 08, 2016 6:18 pm
Had same fault on a company vivaro van,fine when it was above 5'degrees below that refused to start,went to vx,had new ecu etc,still same,went to a specialist they changed some other bits,still the same,it went to auction 6 months later as lease company refused to spend any more money on it.
martinkettering
Modifications: 3" rear lift
2" front lift
Cb radio
Re: Wont start in cold weather =( by Depressed on Fri Jan 08, 2016 6:43 pm
Thats a good point Robfog i did swap the big relay over from a known working vehicle but it was still the same and yes Martinkettering im now at the very same point where ive just about had enough of it i bought it hoping for it to be a reliable vehicle for the winter months but its been nothing but reliable so far ive replaced the Lower Inlet manifold and it was coughing blue smoke out at between 1500-2000 revs that cured that problem but id also had it in a diesel specialist and all they could say was to advise replacing the maf unit which i replaced for a new one and no change then i had it in eurodiesel in chorley and they said it was the lower inlet selanoid so they disabled that which did make it run ok but low on power (No smoke) so thats why i replaced the lower inlet in the end ive also changed the glow plugs and all the selanoids and had the fuel pump and all injectors tested and replaced the 1st injector and all the injector seals and "O" rings ive replaced all the vac pipes and all the fuel lines and put on a manual priming pump and this week just spent £146 having a new seal put into the rear axle so ive spent a fortune on it and ive now had enough and am seriously concidering getting rid
Depressed
Re: Wont start in cold weather =( by snapper on Fri Jan 08, 2016 8:26 pm
Time to get the multi-meter out and go hunt for either a poor earth or loss of voltage in the glow-plug circuit, especially at the glow plugs and the glow plug bus-bar then if nothing obvious change the temp sensor.
Other than the temp sensor from what you describe the fault most likely lies with the glow plugs. I assume:
You changed the originals with new ones of good quality, the correct length and current rating and not made by some rice growing Chinese person for ebay....
You tested the old ones with a multi-meter to determine the resistance and that they were actually f*****d and then tested the new ones with a multi-meter to determine that they were within the spec tolerances and not f****d.
There is a good LOW resistance earth path from the Cyl Head to the Block and then to the chassis earth point and battery Neg.
