rear spring on swb
rear spring on swb by scooper on Sun Dec 20, 2015 9:03 pm
my frontera is abit sprinng happy on the rear, is there anything other springs i can fit to it so its better
scooper
Re: rear spring on swb by Retro Pedro on Sun Dec 20, 2015 9:23 pm
If it's bouncy would have thought shock absorbers. Have you done the old age test, i.e. push down on the indvidual corners and if it bounces more than 1 and 1/2 times usually means shock absorber not doing it's job.
If it's springs, either coil or leaf, the motor will sag down.
Re: rear spring on swb by scooper on Sun Dec 20, 2015 9:44 pm
will check tomorrow
scooper
Re: rear spring on swb by RatCav on Sun Dec 20, 2015 10:12 pm
Agreed .. this sounds like tired shock absorbers.
If the car looks level then the springs should be fine.
