Dreaded EML
Dreaded EML by crewpunch on Thu Nov 19, 2015 1:38 pm
where do I start guys? Drove my Fronty b 2.2dti to Heathrow, all good. Parked it for nearly 3 weeks. On return started on the button as normal but the engine management light came on and put it into limp. I had it nearly five years, filters are probably due but not desperate, and it's got new vac pipes. Light goes out at low revs but it stays in limp.
You guys have never been wrong
crewpunch
Re: Dreaded EML by martinkettering on Thu Nov 19, 2015 4:16 pm
Check all vav hoses,also does rev counter still work while eml is on?
martinkettering
Modifications: 3" rear lift
2" front lift
Cb radio
Re: Dreaded EML by crewpunch on Thu Nov 19, 2015 4:35 pm
Hi
I did try the vac hoses, but will look again.
Yes the Rev counter is working normally
crewpunch
Re: Dreaded EML by vauxsqueeks on Fri Nov 20, 2015 4:37 pm
If you get the codes read then that will give you a good indication of what the problem is..
Where are you based?
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
