Bluetooth OBD2 reader
Bluetooth OBD2 reader by captain on Thu Nov 19, 2015 11:19 am
Had a Bluetooth OBD2 reader I bought for another car which I have just tried on my Frontera, it worked OK on the other car but works even better on Frontera, it reads a lot more of the sensors and even let me reset the engine warning light on a sensor that seemed to stuck on in fault (not recommended unless you know what the problem is) like many others I have the problem with the speed dial working when it feels like it so its ideal for a temporary solution till I get round to fixing it, mind you I must admit I like being able to chose what type of dial etc monitors your speed and have found it to be very accurate, still got a bit of messing round to do before it gives me all the info on MPG etc but for what it cost its well worth it, so was wondering if anyone else had used one of these and what results they have had be it good or bad.
captain
Modifications: Engine chipped
Re: Bluetooth OBD2 reader by martinkettering on Thu Nov 19, 2015 4:15 pm
What software/app are you using with it?
martinkettering
Modifications: 3" rear lift
2" front lift
Cb radio
Re: Bluetooth OBD2 reader by captain on Fri Nov 20, 2015 11:21 am
Its called OBD check orange engine symbol with red check underneath, there is a free app which I tried first then bought the full one which was only a few quid.
captain
Re: Bluetooth OBD2 reader by vauxsqueeks on Fri Nov 20, 2015 4:25 pm
If your running android then "torque" is also excellent and pretty cheap ( there is also a free version ).
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Re: Bluetooth OBD2 reader by Royoung1 on Sat Jan 23, 2016 11:31 pm
how did you get this to work, tried a OBD2 bluetooth device and the phone wont connect to the ECU! please help as only obd device that works of the op-com obd with op-com software only
Royoung1
Modifications: swapped manual windows to electric windows, added remote locking, windows, engine start via bluetooth from custom made app. 80/20 MT tyres
Skype Username: robert79561248
Re: Bluetooth OBD2 reader by stretch on Sat Jan 23, 2016 11:46 pm
What do you mean the phone won't connect to the ecu? it's the obd device that does this, so have you paired your device correctly or is the phone displaying the error 'can't connect to the ecu?' as that means the device can't.
