// Frontera Technical Support • View topic - Crankshaft Sensor
Crankshaft Sensor
Re: Crankshaft Sensor
Postby vauxsqueeks on Thu Nov 05, 2015 10:48 am
1. When you turn the key to position 3 ( crank ) is the MIL flashing?
- If yes, remove key, re-insert key turn to position 2, wait 2 seconds then turn to position 3 to crank..
Does the engine start..
Yes: give the car a second or 2 to read the chip in the key. Maybe a weak car battery?
No: does the MIL flash now?
Yes: This will be immobilizer
No: It's not immobilizer
As you said, no fuel coming from the tank. There is a valve on the fuel rail remove the cap put a rag over the top and gently press the pin to see if there is fuel pressure, fuel should spray out.
If your fuel filter is dry after cleaning then as above check your Pump Relay, when you insert your key and turn to position 2 ( On ) do you hear the fuel pump start clicking/pumping - this will only come on for 1-2 seconds just to pressure the fuel lines then it will switch off.
I would start looking at relay/connections as above and possible fuel pump if you cant hear it start up with the key..
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Postby MartinX on Fri Nov 06, 2015 7:00 pm
Relay seems ok.
Any suggestions on bypassing the immobiliser?
MartinX
Postby vauxsqueeks on Sat Nov 07, 2015 12:48 am
MartinX wrote:Relay seems ok.
You didn't say if the MIL was flashing when cranking??
Did you check fuses?
I assume not then your probably looking at a replacement fuel pump.. Can you hear it comeon with the ignition for a couple of seconds? Did you check the fuel rail pressure?
No, you can't bypass the immobiliser unless you can re-program the ecu to ignore it.
Now Gone
vauxsqueeks
Postby caesium on Tue Mar 14, 2017 6:05 pm
Did you get this sorted?
caesium
Vehicle Name: Shoot Truck
Modifications: 2" Lift on ES9000's
Isuzu Trooper steering wheel
Viper total closure alarm
2 Huge HID spotlamps
Entirely Raptor Coated
DAB Radio
Plenums Removed and Oil Catch Tank fitted
Bonnet ducts for heat management
Postby ghosthunter on Thu Mar 16, 2017 10:34 pm
When you turn on the ignition listen carefully for the fuel pump. It runs for a short period to raise pressure and then stops. You can hear it from inside the car,or get someone to listen outside the car near the tank underneath the car. Do not turn the engine over......just turn the ignition on. If you can't hear the pump then there's no voltage getting to it or its bust. Some people have had the power lead to the pump corrode and break off. If the immobiliser lamp flashes whilst cranking the engine then that usually indicates an immobiliser fault. It is possible to run a separate live feed to the pump to check its working. Be careful...fuel and sparks don't mix!. So you should hear the pump as you turn the ignition on for a couple of seconds max and then it stops. Turning the ignition off and on again repeats the cycle.....if you can't hear it you've found your problem, then you just need to find what's causing it
ghosthunter
Re: Crankshaft Sensor/failure to start
Postby DGrayFisk on Fri Dec 08, 2017 5:58 pm
Hello,
This is my first posting - on behalf of a friend to whom I sold my 3.2L Frontera.
Like another member here he recently found the Frontera would crank, but not fire. His mechanic friend said it could be the crankshaft sensor, whereupon we ordered one on EBay which, it transpired, came from China. It's now been fitted - but the vehicle still will not fire. Any suggestions?
DGrayFisk
Postby stretch on Fri Dec 08, 2017 6:46 pm
Is the eml on codes been read? There have been many reports about using ebay crank shaft sensors. Bosch all the way this is recommend in every post about them on here.
