Frontera Technical Support • View topic - prop shaft damage
prop shaft damage
prop shaft damage by pot bellied pixie on Thu Oct 15, 2015 9:06 pm
Not sure if this is the right place but here goes.
Yesterday I performed am emergency stop and heard one almighty bang like something heavy flying thru the cabin into the back of the passenger seat.On close inspection today in the daylight I found that the torsion bar adjuster bolt had snapped.Some part of the bolt/washer combination made contact with the prop shaft and put a penny sized dent in it .Will this cause me any problems due to imbalance etc?
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: prop shaft damage by andytats on Thu Oct 15, 2015 10:03 pm
If it was me I would replace the propshaft because it may of cracked the steel under the paint.
Re: prop shaft damage by gregster on Thu Oct 15, 2015 10:58 pm
I've got a 2.5 rear prop I can send up if you need one mate...can grab you a torsion bar adjuster bolt to...
Can have shipped tomorrow, for delivery monday....or possibly saturday even (but the couriers charge a lot more for that)...
Prop vibrating even slightly can damage the output on your TF box, and the pinion bearings (new axle) so I wouldnt chance it mate like Andy said.
Re: prop shaft damage by snapper on Thu Oct 15, 2015 10:59 pm
Change the propshaft AND check the end of the transfer box from the joint in the casing to where the rear prop fits.
Don't end up doing this....
Re: prop shaft damage by gregster on Thu Oct 15, 2015 11:24 pm
Re: prop shaft damage by pot bellied pixie on Fri Oct 16, 2015 10:54 pm
Thanks Greg .sorted the bolt how much for the prop posted to Liverpool?
pot bellied pixie
Re: prop shaft damage by gregster on Mon Oct 19, 2015 10:28 am
You gotta pm bud
Re: prop shaft damage by pot bellied pixie on Mon Oct 19, 2015 9:15 pm
Replied :)
pot bellied pixie
