Frontera Technical Support • View topic - 60 mph Shakey ride
60 mph Shakey ride
60 mph Shakey ride by OllieC on Mon Aug 10, 2015 4:33 pm
My 2003 frontera 2.2 DTI shakes badly Above 60 mph, any thoughts to why this is?
OllieC
Re: 60 mph Shakey ride by gregster on Mon Aug 10, 2015 5:48 pm
Tyres out of balance, or wheels full of mud??? I would check these first, along with that the wheel nuts are tight...
Re: 60 mph Shakey ride by Rifleman on Tue Aug 11, 2015 9:35 am
Does it come up through the steering wheel?
Re: 60 mph Shakey ride by OllieC on Tue Aug 11, 2015 8:33 pm
Hi Keith,
Yeah it vibrates through the steering wheel, We've checked all the tires, swapped them all around, had it up on the lift and driven it to 60mph in rear wheel drive only and it still starts to shake at 60mph+. It drives very well all the way up to 60mph. Have you got an idea as to what it might be?
OllieC
Re: 60 mph Shakey ride by geeks on Tue Aug 11, 2015 9:53 pm
Wheel Bearing?
Stuck Caliper?
Completely knackered track rod ends?
Ball Joints?
Errrrr i feel like i have parts tourettes now so i'll stop :)
geeks
Vehicle Name: The Hulk MK2
Modifications: To Come:
Stuff...
Also:
The Beast (2.8 SWB A Series)
Previous:
Skype Username: geeksandlies
Re: 60 mph Shakey ride by bhcalcutta on Tue Aug 11, 2015 10:20 pm
bhcalcutta
Intek CB
Kenwood head unit
wound up torsion bars
monroe adventure front shocks
avm manual lockers
Modified TLC80 Snorkel
Trooper clutch
flappy paddle delete
egr delete
Re: 60 mph Shakey ride by OllieC on Tue Aug 11, 2015 11:29 pm
Right plenty of things to check there! Frustrating as she drives brilliantly up to 60mph, Once we identify the problem and rectify it she will be a pleasure to own! I will report back.
Many Thanks
OllieC
Re: 60 mph Shakey ride by dave1966 on Wed Aug 12, 2015 1:58 am
This will be interesting to see what the problem is, as my dti does the same just now.
R.I.P Sable!(2005 to 2013)
dave1966
Re: 60 mph Shakey ride by RatCav on Wed Aug 12, 2015 9:06 am
Rear propshaft UJ would be my guess.
Re: 60 mph Shakey ride by Rifleman on Wed Aug 12, 2015 9:48 am
The propshaft may be out of balance. Check that there is any evidence of a weight being thrown loose. You will see the area where it was very easily.
If it has a centre bearing, make sire it has no play, and the bush holding it to the vehicle isn't worn.
Is the rear gearbox mounting worn? See if you can lift the box at the rear by hand. If so, replace the mounting.
Re: 60 mph Shakey ride by dave1966 on Wed Aug 12, 2015 5:08 pm
I know things that it isn't on my dti and that is, brake calipers, discs, bottom ball joints and track rod ends as these were all replaced with new ones last year. My brother reckons on mine could be a wheel bearing on the front and he is going to look at it for me at the weekend hopefully.
dave1966
Re: 60 mph Shakey ride by OllieC on Fri Aug 21, 2015 8:55 am
Never did get to the bottom of the vibration, I returned the car to the dealer and have since bought another one! (Not from them!)
Thanks again for the help.
OllieC
