Frontera Technical Support • View topic - missing
missing
missing by sharpeshooter60 on Thu Jul 09, 2015 7:58 pm
hi all,ive got the 1998 2.5tds and its started to miss a beat ?[it feels like the fuels not getting there]a slight juddering then its ok,then it starts again?can anyone put me right as ive had this 4x4 for 12years many thanks
sharpeshooter60
Re: missing by snapper on Thu Jul 09, 2015 11:35 pm
Fuel Filter?
Re: missing by sharpeshooter60 on Fri Jul 10, 2015 3:12 pm
sharpeshooter60
Re: missing by snapper on Fri Jul 10, 2015 11:06 pm
If it was my 2.8 I would be thinking...
Fuel filter (done that)
Youve done the Air filter (but then I wouldnt have even looked at that in the first place)
Fuel lines from the tank to the pump (outside chance but hey ho... they do rot out)
Vac pipes
Fuel tank breather
Fuel pick up in the tank (the 2.8 one has a little rubber thing that acts as a non-return valve)
Loose wire in the ECU (yeah, I know the 2.8 doesnt have a ECU, but I think the 2.5 does?)
