Frontera Technical Support • View topic - Winch Bumper Drawings
Winch Bumper Drawings by big jim on Wed Apr 29, 2015 7:13 pm
would anyone have a set of drawings for a front winch bumper for an A series ?
Jim
big jim
Modifications: Diamond Edition
Removed EGR
Converted Flywheel
2 inch suspension lift
Red neck snorkel
Home made roof rack with high level spotlights
Other than that as it came from Vauxhall plus a bit of rust and a few dinks.
Re: Winch Bumper Drawings by 4x4 bobby on Wed Apr 29, 2015 9:09 pm
There is a set on here somewhere fella! Trugge is your man he had one fabricated!!!!! :thumbup:
Re: Winch Bumper Drawings by mudman1988 on Wed Apr 29, 2015 10:06 pm
Iv got that bumper now and iv since made a HD rear bumper to match incorporating a tow bar
mudman1988
Vehicle Name: Victor
Ass tuck
Rear tow bumper
Cb
Side exit exhaust
Egr delete
Re: Winch Bumper Drawings by Trugga on Wed Apr 29, 2015 10:50 pm
Re: Winch Bumper Drawings by big jim on Sat May 02, 2015 9:09 am
Thanks Trugga,
Do you have any technical drawings with dimensions , fancy a go at making a bumper but don't fancy the pain of the design !!
Jim
big jim
Removed EGR
Converted Flywheel
Red neck snorkel
Re: Winch Bumper Drawings by Trugga on Sat May 02, 2015 9:16 am
Sorry Jim, no.
I took those concept renders on A3 to the Total Off Road show at Donnington and discussed my requirement at length with the guys on the 4x4 R Us stand - we arranged to meet up a few weeks later and they took their own dimensions.
A few years down the line, it appears there are subtle differences in the real world dimensions of the Frontera (for example, wilberforce removed the winch bumper off my old 2.8LWB and tried to fit it to his 2.8LWB - it would not fit).
Therefore, to garentee a good fit, it would appear a bespoke solution to each vehicle is required.
Re: Winch Bumper Drawings by JEOH on Sat May 02, 2015 9:45 pm
Hi Jim,
as a friend got an industrial ARB Bumper for his Frontera and even that had to be customized / adjusted to fit properly, you should design it for your car dimensions.
Just have a look for the front 'dents' of the frame to weld the base-plate in, then do the new bumper by scratch around it. Fixing the winch to a bumper alone won't be tough enough for wrecking purposes.
Kind regards,
Sorry for my pigeonenglish.
JEOH
Vehicle Name: Gentile
EX-GIGANTE (1998) 2018-2022
General Grabber AT2, Soft-Top
G-Wagon Mercedes 300GE 1990
Re: Winch Bumper Drawings by Retro Pedro on Sat May 02, 2015 10:34 pm
There was an old post running from 2013 where somebody Colley knew was making. Not sure it there still being made, if not, might give you some ideas if you can get somebody to knock one up for you.
If Jim (Wilberforce) doesn't mind me mentioning, I did see an old post where he had a PDF of a winch plans.
Here's the link to the initially mentioned old post:
viewtopic.php?f=14&t=47813&start=40
Re: Winch Bumper Drawings by snapper on Sun May 03, 2015 10:30 pm
Re: Winch Bumper Drawings by yaki on Mon May 04, 2015 9:30 pm
There was a company making tubular winch bumpers to order for the Frontera however the name evades me at the moment, if I don't try to think about it then it may come to me (old age setting in) :oops:
Re: Winch Bumper Drawings by yaki on Mon May 04, 2015 9:36 pm
If you fancy the drive, you are welcome to come and measure my winch bumper. I didn't make it, it came with the SWB
