ABS warning light
ABS warning light by crewpunch on Tue Apr 28, 2015 9:11 pm
Hi. After replacing discs and pads all round plus both outer CV boots on my 2.2dti. I now have the ABS light on, any ideas. Thanks in advance
crewpunch
Re: ABS warning light by gregster on Wed Apr 29, 2015 12:49 am
Might be worth checking the connections for the abs sensors, and check you didnt crack the abs rings when you fitted new discs.
Re: ABS warning light by crewpunch on Wed Apr 29, 2015 9:37 am
Thanks
I suppose I'll have to strip them down and check.
crewpunch
Re: ABS warning light by vauxsqueeks on Wed Apr 29, 2015 1:05 pm
Its probably worth while also carefully cleaning up the abs rings and sensor with a wire brush just to remove any dirt, mud etc..
Fronty B, 2002 3.2 V6
Now Gone
Fronty A, 1995 2.4l LWB
vauxsqueeks
Re: ABS warning light by Hawkmoon on Thu Apr 30, 2015 2:38 pm
Crewpunch! if you can test the sensor, put a meter across the 'white' and 'black' connections see if you get a reading of about 2.4 ohms!
See here:
viewtopic.php?f=41&t=11581
If you don't the sensor maybe dead and may need replacing! :(
I had a sensor (well both) die on me,and thanks to this post:
http://fronteraowners.co.uk/viewtopic.p ... nsor+mazda
:thumbup:
I replaced them which looked like this!
viewtopic.php?f=23&t=57692
:thumbup: :D
Better to be late than to lie in state!
Fronty 'A' - 2.4 LWB - 5 speed. named: Godzilla (it was green!) ;-)
Fronty 'B' - v6 3.2 ltd - Silver LWB - 5 speed manual.
Hawkmoon
Modifications: none
