Diesel or petrol?
Diesel or petrol? by fred on Wed Apr 22, 2015 4:37 pm
Hi all,
Not been on in a while coz the frontera I had started to need a lot of work so I've had a car for a bit now,
But as the kids are grown and leaving home we want to do a bit more exploring around the country and I've always liked driving the fronty better than a car on long trips so the question is....
Which would be better a petrol with lpg or a diesel.
Was looking at the 2.2 petrol & diesel and maybe a v6 with lpg.
Still don't know if it'll be a swb or lwb.
Any advise on the lpg (being good or not) would be great coz I've never used it before.
fred
Registration Year: 1994/M
Modifications: swb...
16" pajero alloys with insa turbo special tracks on.
rear window tints.
suspension & 3" body lift.
snorkel.
bullbar extended.
petrol tank lifted higher.
30mm wheel spacers.
3 point harnesses
Re: Diesel or petrol? by stretch on Wed Apr 22, 2015 4:54 pm
Personally i run diesels but the 3.2 on gas gets good reviews as well.
Re: Diesel or petrol? by ghosthunter on Wed Apr 22, 2015 6:11 pm
Don't bother with the 2.2 petrol its just as thirsty as the 3.2..... I've got both and for long drives the 3.2 wins hands down. There are good reports with the 2.2 diesel, just make sure the pumps been replaced. As for the 3.2 on lpg Deans the man and it won't be long before he reports here :dance:
ghosthunter
Re: Diesel or petrol? by fred on Wed Apr 22, 2015 9:52 pm
So the 2.2 petrols out then lol.
Would the v6 lpg and the diesel be about the same cost to run?
Haven't really taken much notice on how much lpg costs not using it.
fred
rear window tints.
snorkel.
bullbar extended.
30mm wheel spacers.
3 point harnesses
Re: Diesel or petrol? by dazza on Thu Apr 23, 2015 4:55 am
Had the v6 about 3 weeks now, running on gas it works out about 5 mpg better than dti, Oh and the power is wonderful :D
If its clean your not having fun!!!!
UTRINQUE PARATUS
(Ready for anything)
Humber-Yorks 4x4 Response training team HY44
dazza
Modifications: lpg
Re: Diesel or petrol? by fred on Thu Apr 23, 2015 1:56 pm
Well it's looking like it could be the v6 then.
Just need to find a good one with lpg now, seen a couple of "in good condition" ones that weren't lol.
Does the v6 have anything expensive to look out for like the diesel has the pump?
Little things I can fix but any warnings would be great.
Also can you get the lpg tank fitted under the floor (if it's not got it)or would it have to have been factory fitted for that?
fred
rear window tints.
snorkel.
bullbar extended.
30mm wheel spacers.
3 point harnesses
Re: Diesel or petrol? by RatCav on Thu Apr 23, 2015 4:06 pm
Because the B series has a side mounted fuel tank you can get an under boot floor donut shaped LPG tank. This means you save boot space. A good LPG system will get you around 300 miles for around £45 (that is what we get out of our 4.0 V6 Ford Explorer on LPG)
The 3.2 is a very good engine. Only things that can cause issues commonly is Lambda sensors. They are cheap to replace and easy to to swap out.
Re: Diesel or petrol? by Munfred on Thu Apr 23, 2015 9:21 pm
Own a v6 and a dti.
If i didnt have the dti, and the v6 wasnt as modified, i would certainly lpg it, rather than get another dti.
Inlet manifold gaskets are quite popular to go on the v6.
Munfred
Re: Diesel or petrol? by RatCav on Thu Apr 23, 2015 9:39 pm
If I were to get another Frontera I would either get a 2.8 LWB A series or 3.2 V6 LPG B Series on LPG.
Out of the two probably the 3.2 V6 on LPG.
Re: Diesel or petrol? by fred on Fri Apr 24, 2015 1:27 am
Thanks for the info guys,
Think it'll be the v6, have to look for a good one, prob won't be till middle to end of summer (if we get one) though other stuff needs to be sorted first as always :( before you get to buy the fun things.
Thanks again.
fred
rear window tints.
snorkel.
bullbar extended.
30mm wheel spacers.
3 point harnesses
Re: Diesel or petrol? by Munfred on Sat Apr 25, 2015 1:15 am
As standard i used to get 30mpg from my v6. Most i have ever had out of the dti is 38mpg. Take into consideration fuel cost differences and the saving isnt actually that much having a dti over v6.
Munfred
Re: Diesel or petrol? by RatCav on Sat Apr 25, 2015 8:58 am
Unless you get carried away with the 210 BHP of the V6 ;)
