Got the 1997 3.5 V6 GDI. Just clocked over 200 000km and goes like stink (100km/h in 2nd). It's an auto with tiptronic. As far as i know in the last 6 years there has never been any problems with it (had it 5 months but it belonged to the wifes uncle who used it to carry his tools around in the building trade. Being a Japanese import it is manufactured to run on 99 octane. I can only get 91 and 95 where i am so am adding octane booster otherwise she surges abit around 80km/h.
The one issue i did have with it is that it has a variable intake chamber, brilliant when it's working but the seals get brittle where the 2 spindle shafts go into the inlet manifold (the variable intake is vacume opperated). Mine had an air leak throught the 2 seals and when i went to get replacement seals i found out they only come complete with the intake manifold, approx $900 NZ plus shipping
. Took me 5 minutes to get the fittings of the end of the shafts and used 2 o'rings of the same approx size. that was in January and so far so good.
I have read up that it is a common problem and most people remove the inlet manifold and take the butterflies and spindles out and seal up the holes before refitting.
