Frontera Technical Support • View topic - Drill sharpener
Drill sharpener
Drill sharpener by mickh on Sat Feb 07, 2015 11:13 pm
Has anyone tried or got an electric drill sharpener. I can sharpen them on a grinding wheel but it can be hit and miss. Any info appreciated as I have about 50 drill bits that won't cut butter.
mickh
Modifications: 2" lift.
Front winch.
CB radio.
Re: Drill sharpener by horses45 on Sat Feb 07, 2015 11:17 pm
Mick I think 4x4bobby has one but I could be wrong
Re: Drill sharpener by gregster on Sun Feb 08, 2015 10:14 am
Probably steam powered....LOL
Re: Drill sharpener by mickh on Sun Feb 08, 2015 11:00 am
Bit of a Dibnah is he? What have you got Fred?
mickh
Front winch.
CB radio.
Re: Drill sharpener by pot bellied pixie on Sun Feb 08, 2015 11:26 am
All I ever use is the diamond wheel in my angle grinder, does for chisels too and cutting tiles and shortening screws/bolts,shapes wood too oh and it is great for putting a chamfer on soil pipes .It is the original electric swiss army knife :)
pot bellied pixie
Modifications: Now deceased.
Gone to the dark side a
black shogun sport equippe.
Re: Drill sharpener by 4x4 bobby on Sun Feb 08, 2015 6:34 pm
Re: Drill sharpener by mickh on Sun Feb 08, 2015 8:01 pm
Any chance of giving me a clue as to what it is or is it a secret. Not interested if it is steam powered though. :)
mickh
Front winch.
CB radio.
Re: Drill sharpener by mickh on Tue Feb 10, 2015 8:58 pm
Bobby talk to me :wave:
mickh
Front winch.
CB radio.
Re: Drill sharpener by 4x4 bobby on Tue Feb 10, 2015 9:28 pm
Sorry fella! Yes mate it was the one that Lidle did in a case its made by Parkside http://www.ebay.co.uk/itm/PARKSIDE-PBSG ... 1204725743
This one.
Re: Drill sharpener by mickh on Tue Feb 10, 2015 9:46 pm
Thanks Bobby, as they work ok I will have a look at some locally of various types and make a small investment.
mickh
Front winch.
CB radio.
Re: Drill sharpener by snapper on Tue Feb 10, 2015 10:28 pm
:? I don't suppose you can get a 25mm drill bit (not a hole saw) in that magic machine Bobby? I got one here that needs some attention after I blunted it drilling some holes on a Bull Bar.
Re: Drill sharpener by 4x4 bobby on Wed Feb 11, 2015 9:05 am
Its doesn't go that big sorry fella!!!!!! :D
Re: Drill sharpener by jmc on Thu Feb 12, 2015 11:45 pm
Hi snapper
For a drill of 25mm diameter you would need a either a wide grindstone or a belt sander.I do have a large 3 phase belt sander which I sharpen big drills on. Its important to keep dipping them in water to keep cool.
At a pinch, say I was on site, I would have a go with an angle grinder, a bit hit and miss , and probably get it sharp enough with an angle grinder. The other thing to do with big drills is just take the sharp edge off slightly this means they won't snatch the metal and dig in.
Its possible a blacksmith or fabricator local to you could do it for you.
jmc
