Frontera Technical Support • View topic - Cleaning tires of mud before going on "modern" roads
Hi
I just read my legislation and they will fine people that go with mud on so called "modern" roads...Do any one have a solution to cleaning the muddy tires after offroad in mud before going home on tarmac..Usually i accelerate on tarmac and they will clean themselves but i have to do it before going on tarmac..Tricky part..
Thank you
badsykes
Vehicle Name: KIY
Modifications: STOCK ... except MAF unplugged from time to time for (in)sanity reasons..
Go to your local garden centre, buy a 10 litre spray bottle. The sort you pump a pressure into then spray what ever. usually used for spraying weed killer or feed onto plants. I've had one for some time to clean mud and stuff off the lights and number plates or to rinse out the radiator fins when they get muddy. should also clean mud from the tyres.
Regards
Stuart
Fatbaz
Hankook RT03 285/75R16
50mm body lift
i can just see the Tractor driving farmers reaction to that :axe:
jimmybhoy
Registration Year: 2004/04
badsykes
Vehicle Name: KIY
1o lt spray bottle as in a water spray bottle not air.
Loneranger
2 inch suspension lift
2 inch Body lift - pending
33" KL71 mud tyres
winch
I see...
I imagine 10 litre of water carry with me just to spray on tires..Funny really
I am thinking about this stuff:
https://mariag.files.wordpress.com/2008/08/sifon.jpg
badsykes
Vehicle Name: KIY
