ABS sensor
ABS sensor by BlackPearl on Fri Jan 30, 2015 10:16 pm
Can anyone help me where I can find the abs sensor to Frontera B. -2000 3.2 V6
Left side, front axle. My car is equipped with a brake warning contact.
/BlackPearl
I use Google Translate.
BlackPearl
Registration Year: 2000/V
Vehicle Name: BlackPearl
Re: ABS sensor by ghosthunter on Fri Jan 30, 2015 10:55 pm
Have a look here
viewtopic.php?f=23&t=54155&p=596302&hilit=+ABS+sensor+mazda#p596302
People have used Mazda sensors with success......but some people with later models the fix has had problems, but got to be worth a try at the price :dance:
ghosthunter
Re: ABS sensor by BlackPearl on Sun Feb 01, 2015 12:04 pm
HELP!
I can't open the link....!
BlackPearl
Re: ABS sensor by RatCav on Sun Feb 01, 2015 12:19 pm
Re: ABS sensor by BlackPearl on Mon Feb 02, 2015 9:38 am
Thanks for the links. I'll look if I can buy this sensor. Is it the same sensor for the left and right side? I just need the left side.....
BlackPearl
Re: ABS sensor by RatCav on Mon Feb 02, 2015 11:37 am
Yup ... you have to cut the plug off as per the links. That allows you to pull the old lead off through the mounting brackets, and then feed the wire of the new one back through them. Solder/insulate the wires of the new sensor onto the plug of the old one. Connect and your away. Remember to leave enought lead on the old plug to reach the lead of the new one for joining.
Re: ABS sensor by BlackPearl on Wed Feb 11, 2015 1:20 pm
Thank you very much for your help. Now I have installed a sensor from Mazda and everything works as it should.
BlackPearl
